On AMI jukebox, the lifter arm started to put record 45, in the wrong place, it was stopped suddenly, and now the arm will not move. You can place record on turn table and it will play fine. Is there a fuse that needs to be replaced or what could the trouble be, would really like to fix this jukebox.
SOURCE: Wurlitzer 1800 jukebox, plays record
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
SOURCE: wurlitzer 1015 jukebox
wow. a jukebox.
ok, the record rises and plays BUT it doesnt finish the song and the arm rests but doesnt go back to its place thus making the system idle...
am i right?
ok, seems like the needle is the one at fault...
to replace the needle only means that you have to replace the whole cartridge as well It's a simple pull-out / push-in fit.
here is a link for the needles. link
here is for the cartridge link
as the way you described it, apparent solution would be to chagne the cartridge.
thanks for using fixya.
SOURCE: Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
SOURCE: need manual for Wurlitzer jukebox 1015 45
I suggest that you check out the Victory Glass wedbsite for a manual.
www.victoryglass.com
Regards
Alan Hood
ami-man
UK
SOURCE: Wurlitzer Jukebox 1015 OMT won't play CDs
This is a laser unit fault or the pcb under the laser unit. Both are expensive.
