Dell Vostro 1720 Laptop AC Power Adapter (5A 90Watts) by Amstron (Generic) AC Adapter Logo
GEORGETTE COURCHESNE Posted on Aug 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
UNLOCK STICKY KEYS HOWW
HOW DO I UNLOCK STICKY KEYS
Level 3:
  • Dell Master 19,187 Answers
  • Posted on Aug 27, 2012
Dell Master
Level 3:
Answers
19187
Questions
0
Helped
4344643
Points
82261
Keyboard keys wont type. used on screen keyboard to type this. any suggestions?
You might have "sticky keys" so try this:
When sticky keys are enabled, users can access functions that require pressing multiple modifier keys such as "Ctrl," "Alt" and "Shift" at once by pressing one button at a time. If sticky keys are enabled, it is possible to accidentally turn them on at an unwanted time. After turning off the sticky keys, disable the feature to prevent them from accidentally turning on again.
    • Press the "Shift" button five times in a row to turn off sticky keys.
    • Open the "Start" menu and then click "Control Panel."
    • Click "Ease of Access Center" from within the Control Panel window.
    • Click "Make The Keyboard Easier To Use" from within the Ease of Access Center window.
    • Remove the check-mark beside "Turn On Sticky Keys" to prevent sticky keys from being accidentally turned on.
    • Click "Apply" to save your changes and then click "OK" to close the window.
Hope this helps. Good Luck!
How to unlock logitech keyboard foe Ipad
follow this steps and fix it. God bless you
Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
  • 2 Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
  • Sponsored Links
  • 3
    Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
  • 4
    Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
  • 5
    Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
  • Read more: http://www.ehow.com/how_4925264_lock-keyboard.html#ixzz2aZv7Zmdg
    Acer 5510 keyboard is locked
    Please read the instructions fully to fix your problem
    1.Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
    2.Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
    3.Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
    Thanks for using Fixya.Have a good day.
    2answers
    DEL Inspiron 1525 Held down some keys too long, got a warning (filterkeys?)... keyboard is now locked and will not type. How do I unlock it, please help.
    Hi Stan,
    Your issue is just that you enabled the sticky keys of your portable system. all you have to do is to disable it again. Just go to control panel then go to accessibility options. Choose Ease of Access. You will find an option to change how your keyboard works, click on that. You will find check boxes. Uncheck the sticky keys, filter keys.
    I want to lock the keyboard so my daughter can play with the keyboard but not have the buttons do anythiung
    1. Press the Windows logo key + U to open the ease of access center.
    2. Click on the "make the keyboard easier to use"
    3. Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
    4. Follow steps 1 through 3 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
    1helpful
    How to lock a keyboard
    1. Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
    2. Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
    3. Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
    4. Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
    5. Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
    3answers
    Shift key not working
    You have 2 Shift keys on the keyboard. If the other shift key is working then the shift key that is not working is defective. You should consider replacing the keyboard on your laptop. There is no setting on Windows that can disable the shift key.
    **Note : If both Shift keys are not working, Try to check if sticky keys feature on windows is on. Sticky keys should be disabled. To disable sticky keys, Click on start and Go into control panel > Accessibility Options, and under keyboard there is sticky keys. Remove the tick and click apply and OK.
    **If "Use Sticky Keys" is unchecked, that means sticky keys is disabled.
    2helpful
    2answers
    How do i unfreeze my keyboard (vaio laptop) rebooting has not worked and now it is asking me for my password to log on and i cannot as my keyboard has frozen!
    try checking the sticky keys are off .this happened to me once.check user book for sticky keys i think its probably the fn + F1 OR F2 OR SO ON to unlock.
    hope this helps
    13helpful
    How do you lock/ unlock a keyboard
    Press the "Windows logo key + U." This will open the ease of access center. Click on the "keyboard." It will say, "make the keyboard easier to use" next to it.
    Lock your workstation. Press "Ctrl + Alt + Del." A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer
    Lock your work station using the keyboard. Press the "windows key", it looks like a flag, and the "L" key at the same time. This will lock the computer. To unlock press the combination again.
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
