Samsung BP96-01073A E-Series Replacement Lamp Logo
Jim Darr Posted on Aug 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dark Band on Samsung projection TV
61" Samsung DLP TV. Old Bulb exploded after 6 years of use. Bought replacement lamp that appears to work fine except now there is a dark "shadow" area on the left edge (4-6" wide) of the screen you can see the picture just looks very dark like it is being shaded. Removing the bulb and re-seating has not helped. Any ideas? Bad bulb, door issue, etc?
Anonymous
Level 3:
Top Expert:
  • Samsung Master 14,553 Answers
  • Posted on Aug 27, 2012
Anonymous
Samsung Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2715204
Points
48227
Most likely optical engine issue----bad light engine.
5 Related Answers
schwarez
  • Posted on Feb 08, 2008
SOURCE: Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Mar 26, 2008
SOURCE: Samsung 61" DLP 3 Blinking lights.
all 3 lights blinking means lamp has a fault the service manual says replace the lamp. If you need the service training manual for that model let me know and I will post the link as the training manual has excellent trouble shooting breakdowns for that model DLP
Anonymous
  • 184 Answers
  • Posted on Feb 19, 2009
SOURCE: Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Anonymous
  • 17 Answers
  • Posted on Jul 11, 2009
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Anonymous
  • 1112 Answers
  • Posted on Sep 26, 2009
SOURCE: My dlp tv has a shadow about 6'' wide and full ht of tv
Hello: The problem is that a small mirror on the light tunnel has fell off causing a shadow in the picture,. In the past the only way to repair this problem was to replace the entire Optics Engine. But Samsung decided it was replacing entirely to many light engines so they decided to allow and train technicians on how to do it. It involves removing the color wheel and behind it is the light tunnel where light from the lamp shines on to a maybe 1 1/4 inch small block with three mirrors on all sides, your problem is that one of these mirrors has come loose from its side, causing a shadow with the pic still in the background. So if you call a technician to come, if he has'nt had the training from samsung on how to do the procedure then he will want to replace the entire optics engine which is the expensive way of doing it.
So when calling as if they know how to replace light tunnel. There are some adjustments that also needs to be done once it's replaced. To verify what i am saying go to this site to find out more. http://www.avsforum.com/avs-vb/showthread.php?t=758625
Call if you need more info will be glad to help..
[email protected]
Phone: 702-418-1389
1helpful
Had check fan no 2 on tv. I replaced. The bulb is about 6 months old as well. I power on both fans are working the bulb comes on but the tv shuts off after a few seconds before the picture even comes on....
U recheck the tv projection lamp connections,the door latch and the lamp door closed properly and tightly.Yes,if the tv projection lamp LED light indication "LAMP" word it is still flashing or staying on the tv projection lamp some how dying again.The tv projection lamp should be replacing it again.
Tv shuts off after 1 min and the timer light lamp light and power light flash on and off
Hi, My samsung dlp 46 tv did the same thing, it was the lamp bulb needed to be replaced.
It is easy to replace, we replaced it twice. I paid I believe $85.00 on ebay store, discount tv lamps
hope this works!
When turned on the lamp led flashes, the bulb appears to lite up but the picture can take several minutes to come on then the set works fine until shut off. please any ideas ward
If lamp has not been replaced in tv in last 2-3 years then it seems time to get it replace.
Lamp replacement procedure is easy and written in user manual of tv.
Thanks.
1helpful
2answers
We have a Samsung HL-T6176S DLP TV I currently have no picture. When I plug the TV in after a few minutes all 3 little lights in the lower left corner of the TV flash on and off, and still no...
The "LAMP" LED light indication flashes or stay on?The tv projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
5helpful
2answers
Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
3helpful
2answers
5helpful
Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Dark band on left side, Samsung HL-R5668W
the reflecting mirror is likely loose and falling down inside the light reflecting tube. you should have seen the band getting darker and larger,
the small mirror is in front of the lamp and bends the light,
remove the lamp and look down the tube (light path)
1helpful
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
