Increased the size of a picture from one sheet to 6. When trying to print the tiles, it only prints the 1st tile over and over again. I tried selecting the other tiles, but it still only prints the 1st one. What can I do to fix this problem. It has worked before?
SOURCE: Printmaster 18 will not print on HP ColorLaserJet 5M.
Following the description of your problem, I noticed that you are mentionong both sides of the paper, so I am assuming that you are trying to use the 'Double-Sided Printing "
This can be the reason of the problem--> you can solve this issue by setting the program using the "Double-Sided Printing Wizard" in the File Menu
SOURCE: bad install of printmaster version 11
Try reinstalling the software, when finished restart your computer then again try to remove in add/remove programs.
Hope this helps
SOURCE: printmaster gold will not center print job
there should be a box to allow you to enter figures for the margins in the setup print job bottom margin etc put a figure in here usually centimetre or millimetres adjust untill your perfect print test page
Find the setup box ! might find it the drop down menu s at the top of the page good luck!
SOURCE: I am having a problem
Make sure your printer and printer settings in the program are also set for envelopes
