Crankcase could be full of fuel causing it to hydro lock take plug out and see if it will pull over be carefull though if it's hydro locked with fuel it will pump out of the sparkplug hole. the rope may be off of the starting pully as well
William, could not find your exact model, the links below should help as a lot of blowers and string trimmers pull ropes are changed using similar method.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." Quick and Easy Homelite Weed Wha cker Starter Pull Cord Replacement
1. Buy a starter repair kit or get five feet of nylon rope similar to what was in the starter from a Lowe's, The Home Depot or the like. 2. Remove the three bolts holding the starter on the motor and remove any remaining rope on the pulley. 3. Line the hole in the pulley up with the hole in the starter housing and thread the rope through both. 4. Tie a tight knot in the end of the rope and cut the tail off so it won't interfere with motor but not so short the knot comes undone. 5. Thread the other end of the rope through the t-handle and tie a knot in the very end so the handle won't come off and the rope won't be pulled into the starter during the next part. 6. Pull the rope up between the starter housing and pulley and get the rope into the notch in the pulley. Turn the pulley clockwise with the rope in the notch to put tention on the spring. Give it four turns. 7. When the notch gets back to the hole in the housing, hold the pulley and pull the rope back into place from outside the housing. 8. Let the pulley turn slowly so it retracts the rope. 9. You want four windings on the pulley and the t-handle to be held against the housing. If you don't get four windings on the pulley, give the pulley another tension turn (Step 6). If you have four windings and the t-handle isn't held against the housing or you get more that four windings, shorten the rope at the t-handle. 10. Reinstall the starter and you will be back in business.
Have you ever replaced the recoil rope, if you had is it a larger rope then the one that came with it? If so, that could be the cause of the binding. I had that difficulty once.
HELLO. DO YOU HAVE THE USER'S MANUL.? IF NOT HERE IS WHAT YOU CAN TRY.(1) FIRST . TAKE OFF THE AIR CLEANER. AND CLEAN THE FILTER.. USE A LITTLE DISH SOAP LIKE DAMW.DISHSOAP AND WATER. ONLY. WASH & RINCE OUT.! THEN DRY IT OUT. (2) THING TO DO IS PULL THE SPARK PLUG OUT. AND REPLACE WITH THE SAME AS WHAT IT IS IN IT. (3) OR U CAN CLEAN IT WITH A TOOTH BRUSH & A LITTLE GAS ON IT. OR STARTING FLUID ON THE BRUSH .CLEAN IT THEN LET IT DRY OUT. AFTER THEY ARE DRY. (4) PULL ON STARTING ROPE WITH OUT THE PLUG IN IT. 3- 4 TIME'S . THEN (5) WITH THE AIR CLEANER OFF & THE CHOKE OPEN. LOOK IN THE CARBURATOR AND PUSH THE PRIMER BLUB. TO SEE IF IT IS GETTING TO THE CARB.? YOU SHOULD SEE IT OR HEAR IT OR SMELL IT.? IF THERE IS TO MUCH.&. IF THERE IS.! THEN PULL THE STARTING ROPE AGAN 3 TIME'S . (6) THEN PUT A VERRY SMALL AMOUNT OF GAS IN THE PLUG HOLE AND PUT THE SPARK PLUG BACK IN. & WITH THE AIR CLEANER OFF PUT THE CHOKE TO THE STARTSPOT.. PRIME IT 2-3 TIME'S WITH YOUR PRIMER BLUB AND TRY TO START. IT. IF NOT (7) PULL THE PLUG OUT AGAIN , AND PULL THE ROPE AGAIN 3 TIME'S . (8) THEN GET STARTING FLUID AND SQUIRT SOME IN THE PLUG HOLE & PUT THE PLUG BACK IN. ..THEN SQUIRT A LITTLE IN THE CARB & TRY TO START IT . IT SHOULD WORK. . IF YOU DO THE SOLUTION'S FOR THE PROBLEM YOU ARE HAVING THANK YOU . REMBER TO VOTE FOR ME THANK U.?
