I have electrolux ew 845 f washing machine. when it is connected to water inlet for washing, water starts running from drain pipe.
SOURCE: cloged inlet filter
You can also buy new filters to replace the old inlet filters from Home Depot. They are not LG brand they are "generic" filters but they do work. LG does not supply these filters the only way to get them from LG is to purchase the entire inlet valve (keep in mind you have 2 hot and cold) to obtain these filters. You can call the parts dept 888-393-6484 and get the part numbers for these valves and a distributors phone number so you can purchase the valves from them. Hope this helps.
SOURCE: Zanussi FC1200W
have you checked the filter behind the flap on the front of the machine, this could be blocked. if the machine is full of water though you will have to manually drain it by putting the grey outlet hose into a bucket or a washing up bowl. you will also need one or two towels to place on the floor because there wil still be a bit of water left in the ipes even though the drum is empty.
hope this helps
SOURCE: Asko w640 has a water inlet fault
Check the drain line to make sure the water does not siphon out as it enters the machine.
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
SOURCE: check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
Prashant even I have An ew 845 f and my problem is that the door just does not shut and each time i try to lock it it pops open . it seems that there is a problem with the door switch. i contacted the company for the spare part they raised their hands and said that they do not have it and the washing machine is obsolete. now it is just lying there in the corner of my bathroom and it does nothing...so mu request to you is that if you are planing on reolacing your machine then i will readily buy yours for the spares...my email is ...ley me know either ways dude thanks
