I can't get red when using the DTV (1080i) jnput. All other inputs function normally. any ideas?
DTV is HD input but look to see if red lens is lit====set does have a hard reset which might cure it if it is a issue---it is based at the exact model number, a four digit code and the working Mitsubishi remote control.
Hi thanks for the reply. The model is a ws-65908. Do you know what the additional four digit code is. The red lens does function on the other inputs.
The set has 3 hidden menus= Option (one you want)=menu 8270---circuit adjust (stay out of there) menu 8257 and convergence =menu 8257----this is a v17 chassis circa 2001--I used scribd and here is a link for a similar model which has instructions for trying the option reset. http://www.scribd.com/doc/10795045/Servi... do not seem to have the manual for yours but the codes I provided are correct for the model you indicated.
SOURCE: Convergence issue on Mitsubishi
Check your error codes first and see what error it's given. If done right it would last. see ctechnicians.com for how to do error codes
SOURCE: Mitsubishi prjection screen WS-65908
You have a convergence problem,all this sets show this problem sooner or later,you have 2 or 3 amps for the red,green blue colors and this amps go bad and need to be replaced then you have to do a convergence aligment from the service mode and not form the customer controls,a qualified tech should be able to correct the problem since is a common one.
SOURCE: Mitsubishi WS-65908 Error Code 24
If you have an ohm meter, check the resistance from F9A04 to ground, and then reverse the leads and check F9A05 to ground. These supply +24 and -24 to the convergence integrated circuits. The conv ic's may be bad. Also, code 24 usually indicates vertical deflection failure as well. One other check to make.....The pic tubes on this set may leak a few drops of coolant onto the boards. Look VERY carefully for liquid drops on the boards or a green and or white corrosion spot or two on the boards under the pic tubes-near the front of the chassis.
SOURCE: My Mitsubishi WS-65908 color TV
Try to check the PAL,NTSC setting set it to Auto. feel free to send feed back good day and best regards.
Looks like you are going to be working with the following:
1080i (HDTV) • 480p (EDTV) • 480i (SDTV)
Hook up depends on what else you have connected to the TV. If you have nothing connected to the DTV component inputs, I suggest using those, as it will allow up to 1080i. Otherwise, use the 2 other component connections directly to the left of the DTV connections.
