The USB port/socket needs to be replaced it cannot be repaired. It is not an easy DIY job, you need to take it to an IBM laptop repair center or a laptop repair shop.
Check that you do not have any bent pins in the USB connector. If a USB stick/device is inserted a bad way, then you can bend the pins in the connector.
There may be two reasons why the iPod will not charge.
1-the charging port may need to be replaced, look into where you hook up and see if there is any damage to the prongs within. There are very fine connections that lay on a hard plastic stub (charging port) if any pins are bent; out of place; or missing the connection would not be possible and will not get charged
2-the battery may need to be replaced. The battery sometimes dies and unable to recharge if you've allowed the battery to be exhausted completely before charging it.
If the laptop switches off as soon as you insert the usb cable, there is a problem with either the usb socket or the cable. It is a safety system which stops usb power being re-directed down the usb data lines. If you have tried multiple cables with the same result then the problem is with the usb socket. try a different socket (a usb hub will help if you are short of spare sockets). Using a mall light, and maby a magnifying glass, inspect the usb port for bent pins or contacts, some sockets have pins (older dell machines especially) which are not supported at all by plastic backing strip and can be bent easily by inserting the usb plug incorrectly or by children armed with a pen etc. If you find bent pins (there should be 4 pins evenly spaced or 4 metal strips along a plastic backing peice) remove the battery and attempt to realign the strips with a small screwdriver. switch the laptop on and try a usb plug in the socket - make sure you insert the plug gently and squarely (and the right way round). If the laptop still fails, have another go or ask someone else (who is nimble fingered and technically minded) to try it. Don't give up (unless you find the socket is broken ie. missing pins) I can guarantee 99% that this is the problem. good luck
Check the actual ports, visual inspection. Look for consistancy of the pins, and guide. If one is bent or missing, that can short out the ports, or blow out the integrated circuit.
If you are using a usb keyboard, try to start up and go into the setup using the keyboard. If you can, the driver for the ports might be damaged, causing the problem in windows, but not in the bios startup.
You can purchase a usb board that can give you new ports, and deleting the usb hub from the hardware manager (check help) and re-detecting the device might repair a damaged driver.
Sadly, not too much can be done. You COULD try to get in there with a small tool and bend them back, but I don't know how extensive then damage is. If you really know what you are doing, you could find an old device with a USB port on it, de-solder that port off, and solder it onto the keyboard. But If you try that, I really hope you know what you are doing. If not- time for a new keyboard. Or- get yourself a USB 2.0 hub and place it next to your keyboard. I have one stuck to the side of my PC with velcro tape.
One of your usb ports is either damaged or has an object stuck in it causing a short. Unplug all usb devices and look at each port. Note if one looks slightly different from the others. There is a plastic tab that fits into usb plugs. If this tab is bent and touches the side of the port, it can cause the short. If this is the case you may be able to either clean out or bend back the bent tab.
The things that usually go wrong with KVMs are bent connector pins (usually mouse or keyboard) or the switch itself. Inspect the mouse connector for bent or corroded pins. They are easy to bend and straighten, however, they will eventually break off if you do it often enough. If you find one that is bent the safest way to straighten it is by using a .7 diameter mechanical pencil. Remove the lead, and work the pin carefully into the pencil barrel. Once you have the pin inside the pencil gently straighten it by moving the pencil vertical.
If it?s not a bent or corroded pin there isn't a whole lot else you can do other than try to get a warranty replacement or if its expensive enough, repaired.
