When the Edimax was working correctly the WLan or WPS light was a steady green and flashed green when data was being sent. The WLan or WPS light now continually flashes orange. The speed of Edimax now ranges from 18 - 54mbps whereas earlier it was 150mbps. From the Netgear N300 ADSL+ modem Router, Mobile Broadband Edition. There is a Zyxel PoE injector and the cable runs up to the Access Point. Everything is rated at 802.11n. Why does this light flash orange?
SOURCE: No lights(lits)on WLAN-No acces from the computer
WLAN light will give you the status of your wireless connection. If WLAN light is off, it might be a possibility that wireless has been turned off or worse is the device had stopped broadcasting a wireless signal. you may try using 192.168.1.1 to get into the setup page of the device to check if wireless has been disabled.
SOURCE: ADSL light flashing!
what is used this router it is a adsl router or only router if this is only router then you have to connect your adsl modem then only its work properly .
SOURCE: Systems cant ping each other
can u ping ur gateway? and the router too? then make sure all the system workgroup have the same name. use the same IP for all that is automatic use automatic for all, and if manual setting use manual setting for all.
SOURCE: the wlan light doesn't flash
Please check the IP address of modem and wireless accesspoint.
Make sure that Both are in same network.
SOURCE: flashing amber modem light on belking n wireless router
Actually there is no problem with the Modem
First Get the following Information from your ISP
1 ) The Connection Type
2 ) If it is PPPoE then Get the user name and Password
Step 1 : Connect Modem - Router - Computer (Wired)
Step 2 : Open RSP By typing 192.168.2.1 on the Address Bar of the internet explorer
Step 3 : On the Left Side Under Internet WAN Click
Connection type
Step 4 : Leave the Password Blank and click Submit
Step 5 : Select the connection type as given by the ISP
Step 6 : Click Next
Step 7 : Type Username And Password for PPPoE ,Click Apply Changes
Step 8 : There is no need to type Any Host Name for dynamic Click Apply Changes
Step 9 : If it is A Cable connection then
Step 10 : On the left side Under Internet WAN Click MAC Address
Step 11 : Click Clone
Step 12 : Click Apply Changes
Step 13 : Restart the Router
Step 14 : Check the Internet Status
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
