My furnace ignitor is not igniting inducer motor comes on then stop when blower comes on then blink 4 times model # amv911550xa
1. Thermostat calls for heat.
2. Draft inducer motor starts.
3. Pressure switch attached by a small plastic or
rubber tube senses the negative pressure produced by
the draft inducer and closes.
4. Draft inducer runs for 30 seconds to a minute
before you hear a gas hissing sound. The ignitor did
not glow, the flame sensor (a small metal probe about
1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops
with no ignition of gas to heat your home. Your
furnace shuts down and goes into a lock out condition
until you turn your power switch back off and on
again. Then the sequence starts all over again with no ignition of the
gas.
Solution: You
probably need to purchase and install a new ignitor. I would suggest that you
inspect your ignitor closely for cracks. Make sure
you do not touch the ignitor with your bare hands. If
you do not visually see a crack, then you could have a furnace control board
problem or a limit, rollout switch problem. The furnace's
control board might not be supplying the voltage to the ignitor. If
your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right
back off, then you need to clean your flame sensor with light sand paper or
steel wool. You might need a new flame sensor, but most of the time they can be
cleaned an will work well after cleaning.
gas.
Solution: You
gas.
Solution: You
problem or a limit, rollout switch problem. Please see "limits, rollout
switches & furnace control boards" further down on this page. The furnace's
gas.
Solution: You
I dont know because the installer did not leave the book and they removed the code problem on the door please help me
ignitor looks good and I tried to call the number 1-877-254-4729 but they close for the weed end
Most units 4 flashes means limit or roll-out switch open. good luck
Have you tried turning of the switch on the side of the furnace and then back on? Then try furnace and let me know it the ignitor glows. Sorry but without the code and being there this is hard to determine. Steve
If you feel comfortable, remove the ignitor, usually held in with a 1/4" socket head. Be very careful not to bump it. Even the slightest hair line crack and its usless. if you see a crack it needs replacing. There are some companies such as Servall that may carry them and sell to the public. I cannot get the codes online. You might try calling a different htg company than the one that installed it and see if they will tell you what the code is. Also
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
It is ilegal for the installer to take the owners instuction manual. This is to stay with the homeowner, it also usually contains the fault codes. They took these things because nowadays if you have them, with the newer furnaces you can diagnose the problem yourself. Keeping them from bilking you for big dollars. When you talk to Amana I would appriase them of your situation with the htg contractor that installed your furnace. Hope this helps, let me know. Steve
I cannot get the code listing online, But here the # for Amana
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729.. Hope this helps? Any further questions dont hesitate. Steve
It sounds like you have a hairline crack in the ignitor. What does the code chart say for the 4 flashes? Steve
