Minn Kota Deckhand Electric Anchor Winch 40 Lbs. Description Dh-40 Logo
Harry Armstrong Posted on Aug 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minn kota repair manual for deckhand 40
Won't play the line out
  • Anonymous Mar 18, 2014
    wiring for circuit board for a minn kota deckhand 40
  • Anonymous Mar 29, 2014
    BLA code602950
Anonymous
Level 3:
Top Expert:
  • Master 4,961 Answers
  • Posted on Aug 25, 2012
Anonymous
Master
Level 3:
Top Expert:
Answers
4961
Questions
0
Helped
1185183
Points
16067
1helpful
Minn Kota DeckHand 18 won't run
Did you check the breaker and fuse. The strain of a rope foul would trip the breaker.
Page 18 shows breaker in circuit for the DH15 - DH25
https://productimageserver.com/literature/ownersManual/36957OM.pdf
Fuse or circuit protector ' Boating Forum
iBoats https://forums.iboats.com > threads > fuse-or-circuit-pr...
Mar 9, 2021 - I just purchased 2 Minn Kota DeckHand 40 anchor winches. They have built in circuit breakers, but should I also run fuses to them as well?
You would need to strip it and test the motor. You can still get parts by the look of it.
https://www.google.com/search?q=Minn+Kota+DeckHand+18
Minn Kota deckhand DH 25 lock up when up at top out of the water.
Does the nylon rope look bunched up inside the housing. My guess is bad spooling. Let all the link out and control it back in so that it is nice and even.
https://www.wholesalemarine.com/minnkota-dh-25-deckhand.html
There is a phone number in the manual for support
https://productimageserver.com/literature/ownersManual/25449OM.pdf
1helpful
My minn Kota deackhand 35 won't lift a 28lb anchor
How heavy is the line that is attached to the anchor - you need to add that weight to the amount being lifted as well. Some general things to consider: Are you providing the correct voltage and current? Is the wire supplying the motor large enough - or is it getting hot? Check & clean as needed ALL connections at terminals, relays, etc for corrosion and tightness. Make sure the unit has been serviced and lubricated as required.
I have a Minn Kota Deck Hand Ser. No. MK01798492 I can not find a modle # on it. It came on the boat i bought used. it did work now it will not let the ancor down. I took the cover off, found a spring off...
39 2372700 COIL SPRING ??
DeckHand 40, 12 Volt, 25 to 40 Pound Capacity, 2377106 - 2004,2005,2006,2007,2008,2009,2010,2011,2012,2013,2014,2015,2016,2017
DeckHand 40 - parts diagram
1helpful
Minn Kota Deckhand stripped gears
Hello!
Here is a schematic for your Deckhand:
DH40
The install of the large plastic gear is fairly easy if you are somewhat mechanically inclined (you must be if you posted the question ;)
Give it a go, last one I did took about 20 mins.
Mike
Sep 26, 2009 • Boating
4helpful
I HAVE A MINN KOTA DECKHAND 35 THAT WONT WIND UP. IS THERE A GEAR I CAN REPLACE?
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
Jun 09, 2009 • Boating
Top Minn Kota Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Minn Kota Computer and Internet Expert? Answer questions, earn points and help others
