SOURCE: HE5t Kenmore Elite
non existent code. if under warranty call tech support. probably control board. can manually override door lock. by removing lower panel and pulling tab at bottom of lock mech.
SOURCE: Kenmore Elite He5t front load waher
hey there is a temo fix till some body comes to your home if you remove the soap try and reach in to the back of the opening you can rest the spring loaded wheel that controls the soap disspenser and that will stop the clicking and allow the machine to run!!!!! after reading all the post i could find i figured it out now my washer is running fine!!!
SOURCE: Have kenmore elite HE5t giving code F20 help pls
The following link explains the "F20" error code:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
I recommend checking your washer installation for a possible siphoning condition and kinked fill hoses, first, as these are the easiest items to rule out.
If you have questions, please let me know. I hope this helps you.
SOURCE: My Kenmore Elite HE5t washer flashes SUD
Sometimes the SUDS/F35 is because of TOO MUCH detergent. To clear you have to set the cycle on rinse and then keep pouring cups of water into the detergent container as the cycle is going. You might have to do this a few times because if the SUDS message comes up the water flow will stop. Just unplug and try again. Also when the detergent container is finally clear you will see the little rotators gears move around when the cycle starts.
SOURCE: F11 error code on a
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
