Question about Sylvania G-Netbook
How do i remove the sidebar - Sylvania G-Netbook
  • Dark Star Aug 29, 2012
    To Brian Sullivan, Good comment for most operating systems, unforunately it doesn't help me with my Sylvania Netbook which runs on Windows CE. Anybody out there know how to remove the sidebar on Windows CE?
  • Sylvania Master
  • 27,725 Answers
Vista
On the Windows desktop, mouse over the sidebar and right-click on the search gadget you want to remove.
Click on "Close Gadget." The search function is now gone from the sidebar; however, the search gadget is still installed on your computer for future use if you ever decide to re-add the item to your sidebar.
To completely remove the sidebar search gadget from your entire computer, follow the next steps.
Right-click on the Windows sidebar.
Click on "Add Gadgets" to open a window containing all sidebar gadgets installed on your PC, including the search gadget.
Right-click on the sidebar search gadget you want to remove, and click to select "Uninstall."
Click "Uninstall" again when a Windows notification pops up, asking you to confirm the uninstall process.
After you click, the program will automatically be removed from your PC and it will no longer appear on the listing of available sidebar gadgets for Vista
windows 7
Click "Start."
Click "Control Panel."
Double-click "Windows Sidebar."
Remove the check from the box next to "Start Sidebar when Windows Starts."
Click "Save." Now, the next time you load your computer Windows Sidebar will not start.
hope this helps
Posted on Aug 25, 2012
6ya staff
SOURCE:
I want to delete movies purchased on my iPhone 4
iOS: Device not recognized in iTunes for Windows
I would start with
Removing and Reinstalling iTunes, QuickTime, and other software components for Windows XP
or
Removing and reinstalling iTunes, QuickTime, and other software components for Windows Vista or Windows 7
If you have iTunes 11 turn on the Sidebar. Go to iTunes>View and click on Show Sidebar. You can also do a Crtl+S to show the sidebar. The sidebar is where Devices appears. and Control+B to show the Menu bar
Next try another computer to help determine if you have an iPod or computer problem.
The update problem typically indicates a either a network problem or an Apple server problem. That happened to be a few times. I just retried and it work after a while.
Feb 25, 2013 | Apple iPhone Cell Phones
Tip
Windows Vista: How to enable or disable the Sidebar
The Windows Sidebar, introduced with Windows Vista, is a way to have one-click access to websites and widgets right from your desktop. Some people love the Sidebar and some people hate it. Whichever camp you happen to fall in, enabling or disabling the Sidebar is a painless process.
To disable the Sidebar:
1. Right click on the Sidebar icon in the notification area (a computer screen with different colored blocks on its right side).
2. Select Exit from the menu.
3. If a confirmation window appears, click Exit Sidebar.
To enable the Sidebar:
1. Click the Vista orb and type "sidebar" into the Search bar.
2. From the search results, select Windows Sidebar. (If Windows Sidebar is the highlighted item, you can just hit Enter.)
3. The Sidebar will appear, in the same place and with the same widgets as the last time you used it.
An alternate way to enable the Sidebar:
1.Click the Vista orb.
2. Select All Programs.
3. Select Accessories.
4. Select Windows Sidebar.
To configure the Sidebar to load automatically every time you start your computer:
1. If it's not already enabled, enable the Sidebar (using either of the methods described above).
2. Right click on the Sidebar icon in the notification area.
3. Select Properties.
4. Put a check mark in the box next to "Start Sidebar when Windows starts."
5. Click either OK or Apply.
If you have the Sidebar set to load automatically and then you disable it, it will still run every time you start your computer, unless you remove the check mark next to that option in the Sidebar properties.
on Jan 09, 2011 | Microsoft Windows Vista Home Premium with...
Tip
How to disable the Sidebar for all users in VISTA.
While the VISTA sidebar can be a helpful tool in the home environment, in the business world it is often viewed as a resource hog which needs to be removed.
In order to keep the sidebar from starting on a computer in VISTA, click on the start menu and open a ren dialog. Type gpedit.msc and hit enter. This will bring up the local GPO snap in. Under the heading Local Computer Policy, expand the section labeled Administrative Templates and then expand Windows Components. In this section you will find a folder named Windows Sidebar. In the Right hand window, double click on the option labeled Turn Off Windows Sidebar and check Enable. Click OK and restart your computer. That's it! Now everyone who logs into that computer will have the sidebar turned off by default.
on Aug 26, 2010 | Computers & Internet
Hi i want to remove the sidebar with the web cam application hen i am on internet i cant see my pages because it shows the sidebar
To turn Windows Sidebar off:
vista_sidebar_icon.jpg 1. Right-click the Windows Sidebar icon on the taskbar (it looks like the image to the left). If you do not see this icon, click the "Show Hidden Icons" arrow (it looks like the image to the right), then right-click the Windows Sidebar icon.
2. To temporarily disable the Windows Sidebar, click "Exit". Or, to permanently disable it:
* Click "Properties"
* The "Windows Sidebar Properties" dialog box will appear. Uncheck "Start Sidebar when Windows Starts".
* Click "OK".
* Finally, right-click the icon again and click "Exit".
To turn Windows Sidebar on:
1. Click the Windows button on the taskbar, enter "sidebar" (without quotes) and press the Enter key.
2. Now, if you want to permanently enable the sidebar when Windows starts:
* Right-click the Windows Sidebar icon, choosing "Properties".
* The "Windows Sidebar Properties" dialog box will appear. Check "Start Sidebar when Windows Starts".
* Click "OK".
Aug 14, 2011 | Toshiba Satellite C655D-S5120 Notebook
Uninstall AVG8so so I can load Kaspersky 2009
in Xp, hit start>control pannel>Classic view(on the sidebar on the left) hit add/remove programs select the program you want to remove and hit remove.
In vista go to start (pearl)>control panel>classic view (on the left sidebar>programs and features select the program you want to remove and hit remove (along the bar at the top)
Apr 06, 2009 | Acer Aspire 3000 Notebook
When opening sidebar windows installer opens .
It is likely some sidebar gadget you've got installed that wants to use bluetooth.
Take a look at the installed gadgets, and see if that makes sense. To administer gadgets (I am assuming the sidebar is not opening properly), but do try to start it, then:
Start
Control Panel
View list of running Gadgets
Remove any gadgets that may cause the trouble.
Feb 09, 2009 | Microsoft Windows Vista Ultimate Edition
PLEASE, I just want to remove XM Radio from my Google Gadgets Sidebar. I do not have an account nor do I want one.. I added it by mistake. Google was no help at all.
Uninstall the entire sidebar using the add/remove programs. Then reinstall selecting only the components you require.
Sep 28, 2008 | Computers & Internet
Blue sidebar on desktop
You should be able to disable this sidebar at start up
Aug 04, 2008 | Acer Aspire 3690-2196 Notebook
How to restore windows vista side bar
2 solution for this problem
1) start - all programmes - accessories - windows side bar or
open the Start menu and in the search line type this word: sidebar
and hit Enter key
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Sylvania G-Netbook Logo
246 people viewed this question
Top Sylvania Computers & Internet Experts
Joe Negus
Joe Negus
Mike
Jeffrey Groves
Jeffrey Groves
Are you a Sylvania Computer and Internet Expert? Answer questions, earn points and help others
