Oil pan magnet placement on a juki 8700n
SOURCE: Assembling new juki ddl 5500
Most of the time the rubber inserts have a slot in the edge of them to slide over the ears on the pan , slide them on all 4 corners and then put the assembly into the table , slide everything to the front of the table. the nail will go through both the rubber and the pan. Use a good quality ,oil resistant sealer , between the rear edge and the table to prevent the oil from splashing out while operating . If your corner cushion does not have the slots in them , put the pan in first nail in place rubber goes on top . Sometimes the rubber needs to be trimmed to height for a perfect head to table fit . The head should be level with the top and the rubber also for a smooth fabric flow while you are sewing. Hope this will help.
