Sub distortion
The first thing you can check is the actual movement of the sub you think is broken. Is it stiff, hard to move, or rough. Any of those things could indicate a problem with the voice coil. The next step will require a voltmeter to read the resistance of the sub in question. First check the good sub and see if it matches the other. I'm thinking it probably won't again indicating a problem with a voice coil. If everything checks out fine you can look for obstructions in the sub box that would impede the subs movement. Or even if the enclosure is a lot smaller on that side it could cause problems. Still nothing? Swap the speaker leads (left to right) at the amp, did the distortion change to the other sub? If that happens - start checking RCA cables, head units, and amplifiers. Happy hunting!
-Dynami
