Ryobi Two  18V Lithium-Ion Batteries + Lithium-Ion Charger Upgrade Combo Pack Logo
Anonymous Posted on Aug 23, 2012
Who rebuilds ryobi 18 volt li ion batteries
I have a few ryobi 18 volt li ion batteries that the charger indicates the batteries are defective.
theoisle
Level 1:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 55 Answers
  • Posted on Nov 11, 2014
theoisle
Contributor
Level 1:
Cheetah:
Answers
55
Questions
0
Helped
59731
Points
88
Rebuilding the Lithium batteries is a waste of time and money. For starters the cells cost a minimum of $5 ea and a low power pack takes 5, so now you are in for $25 without doing any work. You can pick up packs on eBay for around $30 - $40 if you shop around. If you know what you are doing, you can strip cells from bad packs and test them to find good ones and then rebuild with those. It can be tricky and you may get mixed results.
Brad
Level 2:
  • Expert 425 Answers
  • Posted on Aug 23, 2012
Brad
Expert
Level 2:
Answers
425
Questions
0
Helped
214148
Points
743
I have used Batteries Plus and had fine results. See if there is one near you.
  • Anonymous Aug 26, 2012
    After I posted the question I found that the local Batteries Plus only rebuilds the nicd and nchd battery packs, I have just tried a total bleed off of one of my li ion battery then charged it back up after spending some time cooling in the fridge. It charged up to a higher level than its prior Failed condition.n
5 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Dec 31, 2008
SOURCE: 18 volt ryobi battery charger...green & yellow lights come on wha
talked to Ryobi and they are vague. It can either mean that the battery is bad, or the charger is bad and another one that maybe the contacts of the battery are dirty or not seating fully in charger. What I would look for in this instance first unplug the charger and look into charging slot to make sure the terminals of the charger are not bent and they come out into the cavity where battery would go. If not gently pull terminal into opening and retry. Sorry I couldn't be of more assistance
joecoolvette
joecoolvette
  • 5660 Answers
  • Posted on Jul 15, 2009
SOURCE: Battery charges but is dead
The battery isn't any good. The charger is just going through it's regular steps. (I know how it is. I just bought two Ryobi 18 volt batteries for my Ryobi cordless drill, reciprocating saw, flashlight,
trim circular saw, combo set. $60 for two batteries)
Anonymous
  • 15 Answers
  • Posted on Oct 10, 2009
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
something is wrong. take it back if possible.
Anonymous
  • 127 Answers
  • Posted on Dec 27, 2010
SOURCE: can I use the ryobi
No. The P110 is for NiCad batteries. Any of the Li-Ion chargers like the P113 are backwards compatible and can charge either but do not try to charge Li_ion batteries in a NiCad or NiHi charger.
JOHN LAPIER
  • 2602 Answers
  • Posted on Jan 16, 2011
SOURCE: Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
P107 red light on green light flashing 2 batteries neither will charge ryobi 18 volt lithium charger working could both batteries go bad at same time
Replacement for Ryobi P107 Power Tool Battery
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
  • Dimension: 135.70 x 76.00 x 107.30mm
http://www.drill-battery.net.au/buybatteries.php/ryobi_P107_power+tool+battery.html
  • Type: Li-ion
  • Volt: 18V
  • Capacity: 6000mAh
  • Color: Black
  • Weight: 898g
Can I buy a battery charger for a ozito drill
hi Terry.
you could try homebase.or ebay will have them.
or this link should show you where you can buy them.
battery charger for ozito drill Google Search
Dec 02, 2017 • Drills
2answers
I currently live in Europe and have a Ryobi CHP-1802 drill with an 18 volt Li-Ion battery. The charger is a Ryobi BCL-1800 220 Volt, 50 Hz. I am moving back to the United States and want to keep thi
After looking at the manual for your charger, it looks like most of the Ryobi chargers like the P113, P114, P117, P118 will charge your battery. The connector on the battery looks the same as the P103 and P104 used here in the U.S.
3helpful
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
1helpful
Earlier this year, I purchased a new Ryobi P103 LI-ION 18 V/24 Wh battery powered blower. In the past week, the battery isn't holding a charge for more than 5 or so minutes. Any suggestions?
Try to discharge the batts to the full end.Then try charge them agian for at least 12 hrs.
Or contact them at https://register.ryobitools.com/contact_us/new
When putting the battery in the charger the red and green lights flash indicating a bad battery, cannot charge battery.
Have you tried just waiting a few minutes, it might start to charge anyway. But if not, is there some reason you would assume that you don't have a bad battery? There are lots of bad Li-Ion batteries.
2helpful
2answers
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Top Ryobi Drills Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
