SOURCE: oil ratio
you can use a 40:1 mix if it smokes then cut it back to 32:1 but a little more oil is better than not enough so start with the 40:1
SOURCE: how do you sharpen the hedge trimmer
DREMEL STONE WORKS THE BEST. THEY SUGGEST TO REPLACE BLADES
SOURCE: how do i replace the pull cord on the ht-22
Remove the housing with the coil in it. Remove the screw on it, its the screw with about 3/8 washer on it. It is where the old rope was hooked up, and should still have a piece of it under the washer. It has a D shaped groove under it. take the new rope and burn the frays on it make it stiff and small. Turn the pulley around and around until it gets real tight, and align the hole in the pulley with the hole in the shroud. Take a c clamp or visegrips and clamp it in place if you can. I just hold it, then feed the rope through the hole in the shroud and pulley and rap it round D shape groove. Replace the screw and washer. Tighten it up then let go of pulley. It should zip up real quick and all way to the handle, and be real tight.
SOURCE: homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
you can use a ryobi one charger for this!
