How to remove oven door. Something has spilled between the glass.
SOURCE: Whirlpool oven
if you get down to the control panel first try plug and unplugging all the connectors as resistance can cause this in the connectors next take the Mylar ribbon off the control and clean it softly with a pencil eraser as the touch pad malfunction can cause now if you have an ohm meter you can ohm the oven probe it should be 1200 ohms at 70 degrees room tempture if all this fails to fix it then replace the controls bd ive seen too many techs too quick to replace a 200.00 control board just because the eoc spouts out an error code
SOURCE: Whirlpool super Capacity 465 gas range-Door Lock
your latch is defective. they have parts that melt when you use the self cleaning cycle. they also just go out. the door should auto latch when you start the cycle but it times out when it is not seen.
SOURCE: whirlpool gold electric range control panel blinks w/all lights powers oven off
you say after 5 min of plugging in , is this brand new and still covered under your 1st year warr???if so get an authorized servicer out there to take a look at why should you be responsible for their problem
SOURCE: changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
SOURCE: whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
