I have an electronic background and would like to try to try to repair this camera myself. I tried to take it apart but I don't have the tri wing screwdriver thats required. I would like to know what size tri wing screwdriver is required and what parts are usually associated with this error. Are parts available and what is the approximate cost.
SOURCE: What size triwing screwdriver is required for A345. Which shop offers it in Toronto. Thanks!
How old is your camera, where did you buy it and how long ago, and where are you, what city are you in, and I will pull up the schematic and figure that out for you, let me know.
Aloha
Bobby
SOURCE: Zoom error
hi i had the same problem with mine,i took the case apart but could see nothing untoward,reassembled it and just out of frustration i turned camera on if you listen carefully you will hear a whirring sound as soon as it starts turn camera off do this repatidly a few times but do not let the motor finish its cycle,hey presto no more fault. i can only assume that the motor sticks and by turning on and off really quickly frees it up...
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom
button, the lens pushed out again and the camera worked normally for
that time. I had to go through that procedure every time I turned the
camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
SOURCE: Zoom error
Knocking the bottom of the lens end of the camera 3 times on a wood table, medium gentle, fixed a zoom error (where it would not focus in zoom)
The camera had been dropped whilst skiing holiday and this method fixed it. Very Happy!.
SOURCE: Fuji FinePix A900 Digital Zoom error
Same problem with me. Got a zoom error. I thought "it's still under warranty, so Fuji will help me out." WRONG! Fuji repair claims it has impact damage, but that's not true. The product is just defective. Fuji charges $113 to get it repaired. It cost me $140 from Dell only 7 months ago. Defective.
