I called Moultrie service earlier. My nite pics are non-existent. They recommended a new SD card,which might help you. Rec: Sandisk. Avoid " Ultra, High Speed,Dmpina, Mini, Micro, PNY, Max Flash, Extra flash, and Premium. The number @ Moultrie:800-653-3334. Good luck.
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Go to www.moultriefeeders.com...under mini cameras find the M80...open "full details"...scroll to bottom and find manuals/downloads...where it says upgrade click and download to your pc...be sure you download for your camera as Moultrie named all their camera downloads the same, but each is model specific...it will download as a compressed file.I use windows to extract file directly to NEW SD card installed in my PC's card reader slot.If your computer doesn't have a card reader, connect one thru a USB port. Once you have upgrade unzipped to the sd card, put card into the M80 and switch the camera to the "aim" position....should show "upgrade NO"..press up/down key to change to "yes"; press enter and wait...DO NOT TURN OFF CAMERA AND USE NEW BATTERIES...camera will turn itself off when done.Power on camera and test it out.This has solve the trail err and a few other issues with the M80.
M80.
try another card...these M80s are sensitive about SD cards, and a card used in one device won't work in another M80??? Do the SD101...Check the write protect switch on side of SD card; make sure card slot has no debris or bent pins...blow it out with duster or contact cleaner.
