This router is about 3 years old and never had a problem. al of a sudden today when i get home i have no connection and check my router and all the lights are blinking green non stop. at first in a certain sequence and then they start to blink at same time. have not found any help online so far. ive turned off for minutes and reset, same issue occurs. any hellp appreciated, thanks.
SOURCE: D-link dir-615 cannot connect to internt
it could be a problem with your internet connectivity. check with the isp.
SOURCE: D-Link DIR-615 Internet LED light not working
Even though we need more info to resolve the issue, I will make a guess here. My guess is that your D-Link is not configured right, (ie. not pulling the proper info from your ISP's DHCP server.
Try restarting the router and restart or repair your network connection on your pc. Secondly, try to do a "hard reset" on the router, or restore to default. Then reset your connection on the PC. Third, manually set the info on the router.
If you are wireless, you have a whole different issue.
SOURCE: I have a D-Link DIR-615, and the laptop says the
You have not configured the DHCP or manually allotted IP address to the system or possibly a wrong IP address. This is the reason for limited connectivity.
The light blinks when it scans for the wireless devices nearby and as well as for data transfer.
SOURCE: Problem for D-Link DIR-615 Wireless Router, Orange Power Light
I have had multiple problems with these routers. They tend to drop signals or have other issues that are hard to explain in a few short sentences.
After you rebooted did you open your browser and type in the IP address to connect to the router software?
can you be more specific?
Testimonial: "There was a problem with router itself, after replacement everything works fine. Thank you for an advice"
