How to fit belt on flymo tc380
Too replace the belt you need to remove the motor and base plate assembly, remove the box, remove the front cover over the motor, pull the two wires off the motor terminals, turn the mower upside down,remove the blade bolt and blade, remove the impellor, remove the four cross head screws underneath, there are two more screws toward the front of the machine, once all out the motor and base plate will come out as an assenbly, slacken the four motor screws and push the motor forward, remove the old belt and fit the new one, wedge a screw driver between the motor housing and base plate force the motot forward to tention the belt at the same time re tighten the motor screws, re assemble in the reverse order.
