Try 1234 or 0000 if they don't work,you can get the master reset code for Nokia 1110 model phone at Mobile-unlocker.com
and reset it ...
SOURCE: i forgot my security code for my nokia 1110(i) my imei is-356268/01/510003/8...thanks
IMEI: 356268015100038Mastercode: 6446016173
Use this calced 10 digits mastercode at the same points where the phone normally asks U for the security code.
SOURCE: Forgot security code for nokia 1110i-rh93
Hi Friend,
The security code is as follows,
For Nokia 1110i--------3777476375
For rh-95------------------6017702052
Regards,
Ayyasam
You may kindly note that the default security code for all Nokia handsets is 12345. In the event the security code is changed and you are unable to recall it, then the phone needs to be reset. You may kindly note that the security code can be reset at any Nokia Care Centre. Kindly be aware that there will be a service provision fee associated with this service, as it is a non-warranty procedure.
You may kindly note, once the phone has been reset, all data in the mobile will be lost. I recommend you take along the proof of purchase/receipt while visiting the Nokia Care.
Good Luck.
Thanks for using FixYa.
SOURCE: nokia 1208 code 0550593 type rh-105 imei
hi,
unfortunately 1208 is a dct4+ kind of nokia phone..so far not supported by any master code or online calculator...the best way you can do is go to a nokia care center to read your code by any of the following gadget ,mxkey ,hwk ,cyclone or universal box...
i hope it will help you ,thanks for trusting fixya
