SOURCE: have a emachines e44-v133 baterry wont charge.
A good indication of a failing laptop battery is reduced available battery time when disconnected from mains powers. If you have need noticing this your battery may be on it way out.
Please check the battery is connecting correctly to the laptop and sitting as it should within the laptop case. This will ensure all the correct connections are being made.
If this all seems OK you will most likely have to replace the battery as they don't last forever.
