Computers & Internet Logo
Posted on Aug 22, 2012
My scratch live keeps crashing on launch on my mac book i recently hooked up my itunes to my
2answers
Transfer books from laptop library to my new tablet
What kind of new tablet do you use? If it's an iPad, you are able to download books to iPad directly. Just launch iTunes on your tablet and go to iTunes Store, then search for the book you need and click Get below the book cover.
transfer-books-from-laptop-library-new-oxaxc0rwhkhzilrwacqreyis-2-0.png When you want to download ebooks to iPad, you are able to sync the books with iTunes. Having the latest version of iTunes installed on computer, you are able to connect your iPad to computer with USB and sync ebooks to computer.
After getting the ebooks in iTunes library, you are able to sync the books to iPad easily. The following guidance will show you how to finish the task.
1. Plug iPad into computer via USB, and iTunes will launch automatically.
2. Click the iPad icon and choose Books category in the left sidebar.
3. Check Sync Books and choose All Books or Selected Books.
4. Click Sync at the right bottom to start syncing books to iPad.
After syncing books to iPad with iTunes, you will get the books in the iBooks app on iPad. Now you have an enjoyment. But note that you should shut down auto sync before you sync books with iTunes. To shut down auto sync of iTunes, you need to go to Edit > Preferences > Devices on iPad, and check "Prevent iPods, iPhones and iPads from syncing automatically".
If you have downloaded or got books from elsewhere, you can add books to iTunes at first, and then sync these ebooks to iPad. To add ebooks from computer to iTunes library, you only need to click File > Add File to Library at the upper left corner of iTunes, and then the ebooks will be added to iTunes Book Library.
Visit this guide for more methods about how to transfer books to iPad tablet. http://www.leawo.org/tutorial/download-ebooks-to-ipad.html
tip
ITunes Error 13010 - How to correct this error in iTunes
As with any application in any operating system in this high tech computer industry today, there is always going to an error of some kind. How that error can be eliminated, is always the principal concern of any computer user of a Mac or PC.
One of the errors I would like to provide a tip for you, on how to resolve, is the "Error 13010" error message, which affects users of iTunes in Mac OS X.
The Error 13010 alert, will usually appear when a user is unable to launch and open iTunes. More often than not, however, the fix for this error is a relatively easy one.
Here are steps for you can implement to eliminate this error:
For Mac OS X
• Make sure iTunes application is closed.
• Click anywhere on the blank space of your desktop and Finder will appear near the Apple menu icon located in the upper left corner of your screen.
• From the Finder menu click on Go> then select Go to Folder
• You will need to type /Users/td7/Music/iTunes in the open dialog
box:
• This will take you directly to your iTunes folder.
• Within iTunes folder, locate and remove to the Trash,
the iTunes Library Genius.itdb. file
Once you have removed this file, close the Finder window and relaunch
iTunes.
Launching iTunes will restore a new iTunes Library Genius.itdb file
and as a result, no longer see the Error 13010 alert message.
In the event that this procedure does not allow you to launch iTunes normally, you should remove iTunes and re-install the application.
But don't worry though, you will not lose your iTunes Library, as that remains untouched in the Music folder.
You are simply going into your Applications folder and removing iTunes application and then reinstalling it.
Here is the link for downloading and re-installing iTunes, as needed:
Download iTunes '09 for Mac
So now you have at least one workaround, from a number of iTunes errors, should it manifest, which you can use to resume normal functionality of your iTunes application.
I will be providing more tips in future articles covering workarounds like this, for the various error codes which can affect the functionality of either the Mac OS X platform or any applications installed within its volume.
As always, I hope this information proves beneficial to you in some way, if not now, in the future, should such an error like this adversely affects your iTunes application.
Thanks for reviewing this Mac OS X Fixya Tip.
Regards,
-Mactechtrainer
on Apr 09, 2010 • Apple iTunes
What website can I access my iTunes library at
iTunes is not a website per se, it is an application you can download from here: http://www.apple.com/itunes/ .
iTunes then sits on your computer in your Application folder (in a Mac, anyway), you do not need a browser to reach it. Click to launch or open it and voila. If you already have iTunes in your computer, your music files would be in your Music folder.
I like to keep iTunes available in my Dock on my Mac. Easy access.
Phone number backup
You can do it via following steps.1.Update iTunes to the latest version if you have not updated recently. To find out if you need to update, launch iTunes and click "File" followed by "Check for updates." If you are on a Mac, click "iTunes" followed by "Check for updates." If you do not have the latest version installed, a dialog box will appear asking you if you want to download the latest version. Click the "Download iTunes" button.
2.Connect your iPhone to your computer using the USB cable that came with your iPhone. iTunes will automatically recognize your iPhone and an icon will appear in the left-hand column of iTunes.
3.Click the iPhone icon and the "Summary" pane will appear.
4.Click the "Contacts" tab located across the top of iTunes.
5.Click the check box next to the "Sync contacts with" field.
6.Click the drop-down menu in the "Sync contacts with" field and select a program to sync your contacts with. If you are on a Windows machine, you can choose from four options: Yahoo! address book, Windows address book, Google contacts, or Outlook. If you are on a Mac, your contacts will be synced with the Address Book utility.
7.Click the "Sync" button and all of the contacts on your iPhone will be saved to your computer's address book. Included in every contact will be the contact's phone number. Subsequent syncing will add any new contacts you have entered manually on your iPhone. Hope it can help you.
How to sync my contacts from my mac pro to ipod touch?
Install iTunes onto your Mac, and then connect the iPod Touch, and iTunes should automatically launch. Then, click the 'Sync' button within iTunes.
1helpful
2answers
Iphone will not boot
Can you provide more details?
Do you get a white screen? Sad iPhone logo? When you push power does the LCD appear to light up (dark grey color)?
If you hook it up to your computer does iTunes detect it?
if the phone appears to turn on, try putting it in to recovery mode
  • Disconnect your iPhone from your Mac or Windows computer.
  • Press and hold the sleep/wake and home buttons simultaneouslyfor about 20-30 seconds, until you see a yellow triangle with anexclamation point in the middle accompanied by the text "Please Connectto iTunes."
  • Connect your iPhone to your computer and launch iTunes if it does not automatically launch.
  • You should see the below image
Top Rane Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Rane Computer and Internet Expert? Answer questions, earn points and help others
