Does the gourmet collection have electronic ignition or pilot lights
SOURCE: How do you light the oven pilot on Magic Chef 31000PAW
open the oven. take out the racks and push on the button plan toward the back and left it out of the oven.
you will see a small orfix appromiate middle of the fire ring. light a match to it. put eveything back.
you in business.
SOURCE: Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
SOURCE: I cant find the stove top pilot
Electric Ignition (sparking clicking noise when control knob is turned to "light" setting) do not have pilots. The spark ignites the gas.
SOURCE: Magic Chef LP range produces soot whenever oven is on.
The vent (shutter) allowing air to mix with the gas has shut. Access the burner with the oven off, of course, and look for the shutter (a sliding 'door'). It usually has one screw holding it n place and an elongated slot to permit adjustment. It may also turn. Since your burner is producing soot, you need to open the shutter more. Loosen the screw and slide the shutter open more. Turn the oven on and look for a nice blue flame, and one that doesn't run too far over the burner. Keeping in mind that everything there will be hot when the burner is on, and also for a long time after it is off, you can use a long-bladed screwdriver to push the shutter back and forth to get the flame you are looking for. If the screw is loose, a gentle tap will be enough. When you are see that optimum blue flame and you are satisfied, let the oven cool off for an hour or so, and final tighten the screw--making sure you haven't moved the shutter much when tightening. If this doesn't work you have a bigger problem and need to call a service person. Your local gas company sometimes will direct you to a person.
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
