SOURCE: pls reg h/s
Follw the instructions below for the hanset that is not regestered.
The full manual can be downloaded from http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?mode=search&session=20100302153603_80.3.156.26&scy=GB&ctn=CD1501B%2F05&ds=CD1501B%2F05&slg=ENG&qslg=on&searchtext=manual&submit=Search
and select 'User manual'
To register your handset manually:
The Master PIN is required before you can register or unregister handsets.
Note
By default, the Master PIN is 0000.
On the base station, press and hold .))) for approximately 5 seconds. LED indicator around the Play/Stop key on the base station blinks.
On the handset, press (menu) key, scroll (using up or down arrows key) to ADVANCED SET and press (OK), scroll to REGISTER and press (OK).
Note
If no action is taken on the handset within 10 seconds, the registration procedure will be aborted. If this happens, repeat Step 1.
Enter the Master PIN when prompted and press (OK) to confirm.
Note
By default, the Master PIN is 0000. WAITING_ _ is displayed on the
screen.
Note
SOURCE: Have new Philips CD150 phone. It say PLS REG H/S,
not sure if you got your phone problem fixed . however i had the same problem and to fix it you sit the phone on the base unit of the phone and press the menu button then go to advanced settings and then registeration . enter in 0000 as the pin and then 'waiting' will appear and your problem should be solved.
