I bought a drain pump for my fisher paykel gwl 11 and replaced it but I'm still getting a fault code. I see on one website that their pump ships with a fuse kit but the one I bought didn't come with this "fuse kit". Is this the cause of the fault codes not clearing? And, if so, what does this fuse do, can I get a generic one at an electronics or appliance store, and then some simple installation instructions? Any help here is very appreciated!
You need to be more detailed in the description. What is the fault code & is it the same code as before the pump was changed? Why did you change the pump? Was the old pump tested & proven to be faulty or did you just change it in the hope that it would fix the fault? I have changed many F&P smartdrive pumps & never seen or heard of any having a fuse. The only fuse is on the main control board, soldered in. If that had blown the machine would not power up, so fuse must be okay. Start from scratch & say what the error code is.
SOURCE: fisher paykel codes
There is a code book inside the top of the washer where the electronics are.
SOURCE: Fisher and Paykel GWL 11
Hi just read your posting.Try this,Put a couple of books under each foot of the machine high enough so you can look under the machine at the pump.Now select a spin mode and push the start button.Does the pump turn on its own?Where is your machine draining the water to,Is it into the laundry sink or some place else.Please reply with this additional information and this will help me in diagnosing this fault for you.Looking forward to your reply.
SOURCE: I repaced the water drain
Click this link to view the schematic service manual of your machine http://www.fisherpaykelparts.net/partmanuals/GWL11US.pdf as you can see from the diagram there are two screws located in the rear of the machine that would need to be removed in order to disassemble the control. Which fuse are you referring to or refer to the part that you are talking about as to part number on the diagram. This way I would be able to locate which fuse you are referring to. I await your reply Thanks
Rick
p.s I think your refering to part number 30 in the first section where it shows the console being removed but would need clarification on if that is what your are refering to Thanks again
I am trying to replace the drain pump which is a simple replacement but now comes with a fuse kit. Can someone please provide instructions on how to install the fuse kit that now comes with the drain pump replacement part?
Can someone tell me how to install the fuse kit that now comes with the new drain pump? As the old model drain pump has been discontinued and now the new one comes with a fuse kit?
