Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button. Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK. Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Simple Steps That Can Fix Printer From Printing Blank Pages: Ā· Press the button next to Menu option. Ā· Now click on the button next to Test menu. Ā· Click on More. Ā· Locate the option for print fonts. Ā· Click on the key next to PCL. Ā· Now the device will print the font list. If you still get blank printed pages, there might be some other issues as well which needs to be sorted out at first. There can be issues in software or hardware which needs to be found out and that can be resolved by professionals. If you need any such help, you can call on our Xerox Printer Support Number +64ā48879116. We will help you with the solution at any day and anytime.
Try this link:
Read the Billing Meter
The total number of printed pages can be reviewed at the Printer Control Panel, on the Configuration Page, and in CentreWare Internet Services (CWIS).
Three meters are available:
Total Impressions
Color Impressions
Black Impressions
The billing meter counts the number of pages that were printed properly.
1-sided prints, including N-up, are counted as one impression.
2-sided prints, including N-up, are counted as two.
NOTE: During 2-sided printing, if an error occurs after one side is printed properly, it is counted as one.
Color documents converted using an ICC profile on applications with the Color (Auto) setting can print in color, even if displayed in black and white. The data prints in color even if it seems to be black and white data on the Display Screen. In that case, the number of Color Impressions is increased.
NOTE: Grayscale images printed with the composite black setting count as color pages because color consumables are used. Composite black is the default setting on most printers.
When printing automatic 2-sided printing, a blank page can be inserted automatically depending on the settings in the application. In this case, the blank page is counted as one page.
View the Billing Meters: IMPORTANT: The Bill Meters track the total number of pages printed for the life of the printer; it cannot be reset. To view the total number of pages printed:
Press the [System] button on the Control Panel.
Press the [Up] or [Down] arrow button until "Billing Meters" is selected, and then press the [OK] button. The Print Volume Report will be printed.
Press the [Down] arrow button to scroll to the required meter. The number of printed pages is displayed below the name.
Press the [Return] button to exit the Billing Meters menu.
is it also when you print blank pages after the 25-50 pages? if so it could be the fuser, if not it could be the imaging unit. Check your magenta imaging unit and fuser roller anyway. If any of them is dirty, replace them.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
About a 95 percent chance that you have a bad print head.You can try cleaningn cycles and also jet substuitution but your problem is blocked jets.
You could have a piece of paper between the drum and print head.
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
I had this problem when I used a generic toner. I installed a xerox cyan toner, then printed many sheets of a large blue rectangle. After about 15 pages the blue started to spread into the shape, after 30 pages the blue was back. Printing a lot of blue was necessary to get the new toner thru the system.
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option.
Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
