What star tool fits screw head to remove screw turning clockwise for removal
SOURCE: after removing allen screw how do i separate chuck
Pry it off with a flat head screwdriver or pry bar.
SOURCE: removing the dewalt DC925 'rohm' chuck
I have a DC927 and a DC926 that I removed 1/2" Rohm Supra SK key-less chucks on. This process is pretty simple. Put the drill motor in 1st gear. Put the clutch ring in drill mode and not in driver or hammer. Reverse or open the chuck all the way. Hold the chuck firmly in a vise and give the drill a good POP counter clockwise. The last step can also be done with a pipe wrench by placing the drill on a work bench and turning the chuck counter clockwise. Continue to un-thread until the chuck is removed. The replacement chuck must have the same mounting process and mechanism. Put a few drops of locktite on the threads and thread the replacement chuck back on. Tighten the chuck using the vise or pipe wrench. Place the short end of an allen wrench in the chuck and tighten down on it. Placing the drill on a work bench, strike the allen wrench with a mallet to finish tightening and locking down the chuck. Congratulations, you have just changed out your chuck.
SOURCE: i cannot remove screws from wood the drill just
The screw is either broken ,the hole stripped out, or screw not into something solid.Try prying up under the screwhead with something as you turn it with the drill
Remove the left handed screw from inside the chuck, put the drill into low gear then lay the machine on it's left side, fit a suitable spanner on to the slot behind the chuck and arrange it so that the spanner is against the work surface. Put the chuck key into the chuck and give it a hard blow so you knock it in an anti clockwise direction. If it is a keyless chuck or you don't have a key try holding the short end of a large allen key in the chuck and knock the long end in a anticlockwise direction. This will work even if you don't have a spanner to fit behind the chuck but you might have to hit it harder. If you have a vise after removing the screw hold the chuck in a vice and fit the spanner behind the chuck and turn it anti clockwise.
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting on the transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
