Hi there:
The lens may be only slightly out of range for correct focus,so it gives the E32 lens error code. Lens errors are a common problem. Dirt can get into the gears or the lens can become misaligned from being carried in pockets, purses or from impact, like yours. With newer cameras I am usually hesitant to suggest these options since they include some more extreme procedures that may cause further damage if not done correctly, but since you did drop the camera, and there is no chance of warranty repair, they may save you an expensive repair bill. The links below give step by step DIY instructions on troubleshooting and attempting to fix this problem. The lens structure of these compact cameras is the same so the examples do apply to this unit. These procedures are effective about 60% of the time.
- http://www.e18error.com/repair.html
- http://www.fixya.com/support/t102982-e_18_problem
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
SOURCE: My camera keeps saying: A camera error was
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
SOURCE: Camera is a Canon Powershot
I am sorry to hear regarding the trouble. This is a common problem.These symptoms indicate a ccd or main board connection defect or both. I would advise you to contact Canon and complaint the same. In the past, there were few recalls for faulty CCD sensor, though not sure if they are still honoring that.
http://www.imaging-resource.com/badccds.html
Unfortunately, there is no home repair. The unit has to be sent for repair. Try to call Canon and negotiate on the repair cost unless investing in new camera is the only option.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
