Hello there. My name is Olga.I bought a business with the cash register TK 1550. However logo on receipts came out with previous owner name company. How I would able to change the logo? or it is impossible? I have tried everything but can't find the answer. Thank you.
This should help:
http://cegap.com/downloads/Casio_TK-1550.pdf
Look at the instructions on preset message or preset graphics.
Testimonial: "thank you"
SOURCE: TK-1550 cash register e037 digit or amount limitation over
It sounds like you have a lock out high amount limitation.
email me so I can send you a picture that will explain it more. My email is [email protected]
In the subject put the Eo37 error code so I know it it from you. The picture explains it, I will try to explain it since it will not let me paste a picture on here. On one of the programming keys it has been programmed (came that way, or accidentally done) that locks the register if a certain limitation of amont of money has been totaled. In your case $30.00. The manual should show or tell you how to unprogram or change the high amount limitation.
SOURCE: How do you Reprint a previous receipt?
Hi. You can't. If you start a new sale, you can't print a receipt from a previous sale.
Mark
SOURCE: casio pcr-t2000A - programming receipt
That just turns the logo on or off. If there is an old logo there, you don't need to do the 2122 command.
to change the name on most Casio machines:
Turn key to Program mode
2 SUBTOTAL
132 SUBTOTAL
Now type the characters for the first line of the receipt using the alphabet on the edge of the buttons. If someone has removed the letters from the keys, just find the alphbet layout in your manual.
00 (double zero button)
CASH (maybe labelled CA/AT)
232 SUBTOTAL
Now type characters for second line
00
CASH
332 SUBTOTAL
Now type characters for third line
00
CASH
432 SUBTOTAL
Now type characters for fourth line
00
CASH
SUBTOTAL
NOTE: You might have to do 2 receipt prints in REG mode to see the changes
If anyone is looking for / needs a Casio PCR-T2000 manual,
http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
SOURCE: With my Casio TK-1550, I'm
I have had this before when the paper was the wrong size. make sure the paper is the same width as the printer and it is covering the little sensor on the printer. Make sure you have closed the platten arm down onto the paper fully. If this doesn't correct the problem, you may have to see a dealer.
If anyone needs more information, the Casio TK-1550 operating and programming manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1550_user_programming_manual.html
