If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this
gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this
electric no heat tip...
heatman101
Try the following basic troubleshooting steps.1. Make sure that the coils are getting power by moving the timer between normal dry and cool down (toward the end of the cycle). You should hear a click to indicate that the circuitry is working.2. Open dryer access panel (usually on the front bottom), and then start the dryer on heat. Look at the burner tube, you should see a glow, for a few seconds and then the gas should start to flow, and the flame lights. Afterward the glowing igniter should shut down and just the flame should remain. What you do next depends on what you observe here.
