Pioneer SD-582HD5 58" Rear Projection HDTV-Ready Television Logo
Posted on Dec 20, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
12-19-08. Two months ago the blue tube started getting brighter, and then going back to normal. Two weeks ago it was doing the same thing then suddenly the picture went black with a loud POP!. We shut the unit down, waited five minutes and turned it back on. The picture came back up, no problems. This repeated three more times over the next few days (Black with a POP). Now the screen is fine, blue tube has'nt fluttered in a while, but since the last POP the tv functions via the remote control are hard to change (i.e Channel changing, screen selection, volume control etc.). I'm wondering if the last POP may have damaged the ir control for the tv. The signal goes flawlessly through the tv to my other components flawlessly, but the inner tv functions are slow to respond. What do you think? How to fix?
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on Dec 20, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
783326
Points
6681
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
THE TV STAYS OFF
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Pioneer SD-582HD5 Picture looks 3D with red and blue copies of images seperated on the screen..
Replace BOTH of your convergence ICs they are big black ICs will have part number on them if 110s use 180s.
Pioneer SD-582HD5 - screen went black, no sound, however the power switch - red light on the front panel is still on
There are actually two fuses on the smps F201 (6.3a) & F202 (5a) if either or both of these are open the problem is not likely the fuse. What I try and tell customers is that a fuse being open is merely a symptom, never the cause.
This particular unit is plagued with poor solder connections which case the voltages to flutter violently and the symptoms you're experiencing... You would be wise to remove the power supply and replace it or have it rebuilt. There are a number of companies that specialize in rebuilding boards of this nature or any qualified shop could do it if they had the whole Tv, since they probably don't have a jig special for that unit.
In summary, check the two fuses above and just be prepared that replacing them won'y solve the problem and most likely just open the new fuses in a short time.
Bill
Premuim Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
50" Pioneer TV blacks out and has shadow on the bottom third
yes it is worth fixing.if you r getting it repaired for the first time.
but you will have to wait for some long time to get it repaired as the tv is very old its very difficult to get the parts for reparing it.
the problem what you r facing is the problem of the convergence in your main board of the tv.
it has to be repaired.
i will advise you to get it repaired as it will work.
for doing it your self you can try clicking this link and following the given instructions in it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Vertical problem
should have taken it back day 1
2answers
Pioneer SD-532HD5
This fault happens with just about any tube type projection set. The convergence IC's simply need to be replaced. They are two black, 2"X3", stand up ICs that will start with the letters STK on the surface of them and are mounted up against a large metal heatsink. If you have the soldering skills this should not be so hard for you to do, but please if you do not have the skills or experience to replace these IC's call in a pro to assist you with this repair. Good Luck
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
