Question about Panasonic Office Equipment & Supplies
Remove misfed paper j45 - Panasonic Office Equipment & Supplies
6ya staff
SOURCE:
Anonymous
  • 16 Answers
SOURCE: how do i remove misfed paper?
I hope the there will be an indicator that wil tel you the position of the moisfged paper,
unplug the copier from the power socket, open the indicating unit and remove the paper, do not force the paper anti-clock, pull the paper through the normal running of the paper.
Jowinson
Posted on Jun 20, 2008
Anonymous
  • 6 Answers
SOURCE: Panasonic Workio DP-2000 j33 problem
The sensor arm just below the registration roller has dropped the spring to return it to it's home position.
Posted on Apr 14, 2009
Anonymous
SOURCE: MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Posted on Apr 26, 2009
Everett Lin
  • 990 Answers
SOURCE: can not print and photocopy on panasonic dp-2330
Hello sir; Check the paper path where the paper stuck,there have a senser , may be come off or out of track, just put it back to right place.
Posted on May 15, 2009
Ickoajnc
OfficeServiceAjnc
  • 211 Answers
SOURCE: showing misfed paper @ U1 U2, paper jam out, but
in the machine can be a little fragment from a sheet of paper so watch careful it can be right on the sensor for registration please open all doors and close them again.
But for i to be able to help you more you will need to tell me what brand is the machine and which is the model
Posted on Jul 15, 2009
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
The printer is saying that paper was misfed and it says that procedure for clearing misfed paper is shown inside the front door : C and A
First you have to open all the doors see their are two papers are get jamed in side, one paper at C section that meens in fuser module and another one in lower papaer tray section you can find the nob of C when you open the front door please rotate that the C jamed papaer comes out and other one open lower right door op tray-2 and tray-3&4, you can see the Ajamed paper remove that and close all the doors if problem exists call expert-thankyou
Dec 15, 2010 | Ricoh Aficio 2035 Copier
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I get remove misfed paper error and there is no paper stuck in it
the paper was stuck in the middle of the printer i had to remove all the printer piece to remove it
Jan 25, 2010 | Panasonic Office Equipment & Supplies
Keep getting misfed paper message. can't see paper
Check the paper tray. The part at the end of the paper might not be keeping the paper pushed to the front of the tray. Remove the tray and check the rollers that feeds the paper. They might be slick. Clean them with some WD-40 sprayed on a rag.
Nov 22, 2009 | Ricoh CL4000DN Laser Printer
Misfed paper
Clean the paper feed roller and select the copy mode paper tray correctly.
Sep 28, 2009 | Office Equipment & Supplies
Apr 23, 2009 | Sharp AL 1631 Copier
Mar 27, 2009 | Panasonic Workio DP-2000P Copier
Remove misfed paper code J93
J93 means = paper remained in adf . sounds like you have a problem with the reed point sensor in the adf door . little black plastic arm , right side should be dangling
Jan 13, 2009 | Panasonic Workio DP-190 Multifunction...
How do i remove misfed paper?
Jowinson
Jun 20, 2008 | Panasonic FP-7750 Black and White Copier
183 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
