Question about Craftsman Air Tools & Compressors
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor wont build pressure and makes a rattling sound. any ideas?
  • Donald P Hutchins
    Donald P Hutchins Aug 20, 2012
    I need some clarification: Is it a new compressor?; Is it electric vs gas powered?;  Is the knob on the valve that adjusts the pressure turned to the correct position?; When unplugged and not operating are you able to shake the compressor and still hear the rattle?
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
Posted on Sep 09, 2014
6ya staff
SOURCE:
John Trevino
  • 1420 Answers
SOURCE: Will not build up pressure
If this compressor is dry type with no oil needed, then it may have a worn cylinder and/or piston ring. With flashlight in hand, look under cylinder with piston in upper most position. If you see scratches most likely it needs cylinder / piston kit. Not to worry, not too expensive. If you compressor has a crankcase with oil, then you may have problems with valves in the head. Cracked or dirt under headvalves will prevent pressure from building. Finally there may be one or several leaks in the tubing, check leaks with soapy water. enjoy
Posted on Nov 29, 2008
John Trevino
  • 1420 Answers
SOURCE: Craftsman 25 gallon compressor wont cut off
The pressure switch has snap action contacts that are opened by a diaphragm pushing against a spring mechanism. Unplug the compressor and remove the cover to the switch and look for the contacts. Make sure that they are not welded together from use. Move the on/off lever to see if they open and close. You may have welded contacts or broken mechanism within switch. A factory replacement is expensive, however if you are a tinker-er you can use a lower price generic pressure switch available on ebay. Switches are sold by pressure range, you need a 120#. Fittings may need tweaking. Enjoy
Posted on Dec 12, 2008
John Trevino
  • 1420 Answers
SOURCE: Pressure won't build up in tank
Your compressor is the oilless type that incorporates a vinyl/teflon piston ring and a cylinder that is open from the bottom. Remove the cover and push the piston to upmost position. Look for scratches along the upper portion of cylinder. If scratched, compression is leaking thru ring and will not fill tank. Replace with Sears part #k0650 cylinder /piston ring kit to restore full power. While the compressor is apart examing the valve plate and reed valves for wear. If worn replace with part #z-ac-0032. Reed valves tend to crack or loose their shape reducing efficiency. If cylinder and ring are in fair condition, then most likely reed/valve plate is the problem. Good luck and email if you have more questions.
Posted on Feb 01, 2009
Anonymous
SOURCE: wont build pressure over 25 psi after rebuild
cagey here i took mine in to be fixed and it was the piston and rings. they couldn't hold over 33psi of pressure.
Posted on Feb 26, 2009
SOURCE: 6 gallon proforce air compressor not building any pressure
You might have a broken valve. You'll need to pull the head apart. But make sure replacement parts are available first. Does this unit have an unloader valve on it ? That could also be your problem. You probably should check this first
Posted on Apr 01, 2009
My craftsmen air compressor wont build pressure. How do i fix it?
If the unit will not build up pressure you need to remove the compressor head from the compressor and inspect both the intake and the exhaust reeds as well as the piston ting on the compressor.
Without the model number of the compressor this is about as far as I can help with.
Sep 30, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 1 HP 4 Gal air compressor runs and sounds like the air pump is working but no pressure is building up
Cold weather will freeze the water the compressor normally makes and this can prevent the switch diaphragm from releasing.... also drain the tank
Dec 27, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
My craftsman air compressor model 919 16737 1.1 hp 17 gal 150 psi won't build up any air pressure. It runs but sounds a little odd.
Probably the check valve has failed. It apparently is where the pipe goes into the tank from the compressor.
Aug 24, 2009 | Craftsman Air Tools & Compressors
Craftsman 1 gallon direct drive oil filled wont build air pressure
It sounds like you may have a broken reed on the diaphragm plate. This is located at the block. Remove the cover, and look for a cast metal assembly with fins. It will be attached to the side.
Apr 18, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
567 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
