I know it has a virus, when logging on it reads ERROR LOADING C:\PROGRA~1\MYWEBS~1\BAR 1.BIN\M3PLUGIN.DLL the specified module could not be found
SOURCE: m3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found. Solve my this problem as soon as possible.
SOURCE: after starting the laptop. it won't do anything
Hi..
In that case your laptop is already infected by the virus, came from your mp3, and it's also display the dll, you need to reformat your laptop the causes of that problem is the virus which is blocking the files you want to execute.
Good luck !!!
Regards
PCmania
SOURCE: Error loding c:\PROGRA~1\myWEBS~1\bar\1.bin\M3PLUGIN.DLL The Specified module
this is from an very good internet friend of mine, I turn to when in need
LSBW
Feb 12, 2009 7:29pm GMT
do the following step and get rid of it.
Open Run , type regedit and press enter
Go to
HKEY_LOCAL_MACHINE \ SOFTWARE \ Microsoft \ Windows NT \ CurrentVersion \ Winlogon
and check for the key Shell, the value of this must be Explorer.exe .
if you can see some other after that like Explorer.exe
C:\PROGRA~1\MYWEBS~1\bar\2.bin... , then remove the second file from the
value, means it must only Explorer.exe
Ok, then check for the key Userinit. the value must be
C:\WINDOWS\system32\userinit.exe, (including the comma) . If after that
some thing is there , then delete it.
Ok thats all. restart your system .
Report
FishTech
Mar 28, 2009 7:29pm GMT
I tried your solution and it wasnt working so I tried
the MSConfig on selective startup and there it was in the startup. I do
not really know why the scenario is a little different but your solution
led me to the current solution. Easy Registry and CCleaner did not help
at all. I tried those to so I could say they did not work and you
seemed to know more about a good repair than did those others. Thank you
for caring enough to post.
Report
Libby
Oct 28, 2009 6:28pm GMT
Thank you!! That totally worked!
Get online
and got to www.google.com In the google search box type: "HP
Support" or "Compaq Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals and search them for Factory Restore or System Recovery.
Why
not just kill the virus or do a System Restore which will allow you to
select a Restore Point (date and time) before you got the virus. System
Restore will not delete your data, documents, music, pictures, videos
or programs (unless the program was installed after the restore point
you selected). System Recovery or Factory Restore will delete
everything and set your computer back to when you first purchased it.
To
get to System Recovery click Start/Programs/Accessories/System
Tools/System Restore. Select a date and time (Restore Point) before you
go the virus.
You could also try downloading and installing MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type:
"Download cnet Malwarebytes" (without the quotes). Download and
install malwarebytes from the sites download.cnet/malwarebytes. When the
site opens up click on the Green Download button on the left. Do not
click the Red Download button, that's junk. When it finishes installing the Gui
Interface will open up with an offer to Accept a Trial Version or
Decline. CLICK DECLINE you want the totally free version. Run a
QUICK SCAN. As it scans, if it finds infections the number will be in
red. When it finishes scanning, click SHOW RESULTS. A notepad text
document will open up showing you the results. You can close the text
document and go back to the Gui Interface where you will click REMOVE SELECTED
RESULTS. The objects will already be selected for you. When it
finishes removing the objects click ok and it will sometimes reboot your
machine.
