Cannot find ny drivers for my old seagate st3320820u2-rk
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html it might take some time being a freeware driver solution note: it will find all of your outdated drivers this is a free driver solutions http://download.cnet.com/drivermax/3000-18513_4-10572602.html Windows 2000/XP/Vista/7/8 free driver program http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html Windows XP/2003/Vista/Server 2008/7/8 free drivers http://www.downloadcollection.com/device_doctor.htm Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use http://www.innovative-sol.com/drivermax/
they will automatically search for and find the correct driver
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
free program, paid update available
hope this helps
SOURCE: disco duro externo
Seagate disco duro externo
si estás usando un cable USB la computadora deberia encontrarlo automaticamente, el programa es solo para proporcionarte utilidades.
si quieres recuperar estas funciones puedes bajar varios de estos en el siguiente enlace:
http://www.seagate.com:80/www/es-la/support/
busca tu modelo y baja el programa recomendado de hecho esos los puedes
usar el mismo programa para varios modelos
si te sirve la ayuda no olvides darme un rating
gracias
SOURCE: Seagate (ST3320820U2-RK) 320 GB USB 2.0 Hard Drive troubleshooting
The problem may be there in your hard drive, try the hard drive with another computer and if the problem persists, go to the nearest Service Center of the Manufacturer.
Hope this helps, Mrityunjay.
