Our booster pump in the condominium does not not function anymore. is rewinding can solve the problem?
I wouldn't consider rewinding a motor of that size unless it's impossible to get a replacement, in which case I'd modify the pump to take a common motor.
It's cheaper to build a small motor than it is the rewind it- it's quite a job to rewind a motor, and small motors are hardest.
Look on the motor tag- you should see RPM, HP and Frame Size. These are the three things you need to know to replace the motor. If the shaft is odd, as it sometimes is in pump motors, you can always just replace the entire motor stator- the housing with the laminations and windings, with one from a different motor of the same brand, frame size, HP and RPM. Again, cheaper than rewinding the motor, but a little more work than just replacing it.
lp
