Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Michelle Posted on Dec 19, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
Need expert advice on the above problem - status light is constant red- we unplugged power and reset, tv green light comes on and then shuts off when red status light comes on. No picture at all. I called someone and we tried to get the timer code - we get 1-8 blinks five times. What could be the problem. TV is only3 mo old.
Thanks you
  • 7 more comments
  • Michelle Dec 19, 2008
    model # wd73735
    MODEL WD 73735
    i definitely heared the ticking sound earlier, i didn't know what it was - thank you
  • Jake Bennett
    Jake Bennett Jan 01, 2009
    just had this probelm. from what you all are saying that is what happened to mine and it was less than 2 months old got ahold of dealer i purchased from they dropped a new tv off to me.
  • spazzizzle Mar 21, 2009
    same problem here. Started making a buzzing noise in the back and then the nxt day would not turn on. I can hear sound but no picture.
  • Anonymous May 11, 2010
    What is the model number of the unit. If t is only three months old, and with the error code you provided, I thin you have a bad colorwheel. You will have to have an authorized servicer check this. Mitsubishi will not release a colorwheel without and authorized servicer getting authorization from tech support
  • Anonymous Mar 13, 2014
    red solid light and no picture or sound on my mitsubishi 73 inch model 73c9
    status light on solid red on 73 inch 73c9
  • eva fletcher
    eva fletcher Jan 21, 2018
    My TV comes on but no picture and I change the lamp.
Anonymous
Level 2:
  • Expert 106 Answers
  • Posted on Dec 19, 2008
Anonymous
Expert
Level 2:
Answers
106
Questions
0
Helped
34847
Points
281
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
  • Darin Whitehead
    Darin Whitehead May 06, 2014
    what :device "button?...there is only the volume,channel select,format,menu,guide,and imput buttons...also has a system reset button...but no deivice button
Anonymous
Level 2:
Sergeant:
  • Expert 233 Answers
Anonymous
Expert
Level 2:
Sergeant:
Answers
233
Questions
6
Helped
104365
Points
555
Turn the tv off, hold down device and menu buttons on the front for 5 seconds, you will get a code flashed out through the LED's.. the codes are as follows:
12   No error detected 22   Recovery from momentary Reset 32   Lamp Cover open 33   Air Filter Cover open 34   Lamp abnormality 35   Chassis Fan failure 36   Exhaust (Back Cover) or Lamp Ballast Fan failure 37   Engine (DMD or Lamp) Fan failure 38   Excess Lamp Temperature 39   Excess DMD Temperature 41   Short Detected 44   DVI Cable (between Chassis and Engine) disconnected
Has solid red status button, no sound or picture
check cables in the back properly hooked - audio to audio and video to video. colour code may help.
1helpful
2answers
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
1helpful
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
The power light is solid red with no light on the status. I took out the bulb and put it back in now I have a solid red on the power and a solid yellow on the status. There is also no sounds coming from...
steady red with yellow/orange status light indicates that the temperature is too high, so by the sounds of it your device has malfunctioned, you need to get a repair on this
see page 44 here
http://vis.mitsubishielectric.co.uk/files/library/files/hc3800_manual.pdf
different model but same error code
Status light on printer is constantly red & USB status is not ava
Unplug printer and wait a few and then plug back in and turn on. Should reset printer.
Solid Yellow light and blinking yellow status light after bulb replacement. TV wont turn on.
Sounds like Mitsu is getting sued left and right about their DLP problems. There is a potential overhaul if you contact their parts department.
Hello Need expert advice on the above problem - status light is constant red- we unplugged power and reset, tv green light comes on and then shuts off when red status light comes on. No picture at all. I...
The 18 code does not exist. To read the code press device/input button and menu button at the same time on the tv. count the LED flashes 1st digit short pause 2nd digit long pause, repeats.
The red status lamp indicates there is no communication between the format board and the DMD board (light engine). The most common problem for this is capacitors on the Format board that require hours of labor and possibly sending the entire electronics package to Mitsubishi if the caps don't do the trick. Expect a very large bill, contact you local Mitsubishi Authorized repair facility about this, DO NOT take a chance on your corner repair shop to know how to accomplish this.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
