Alert message received. Ink absorber almost full. Contact service. How to get to it? Can it be cleaned, or have to replace?
Ink Absorber Full
This may clear the ink absorber problem. There is ink absorbers located at both ends of the printer where the ink head move.
To dry the ink absorber, power up the printer and open the cover so the ink cartridges and print head will move to the middle of the printer.
Then take several sheets of absorbent tissue, fold it into a pad and place it inside the printer over the ink absorber on the far left hand side of the printer to soak up the excess ink. You may need to change the absorbent tissue a few times. Then repeat the same procedure on the right hand ink absorber.
Close the lid and the printer should now function normally.
SOURCE: waste ink absorber full
It's Very Simple
Just Enter in Service Mode of your printer and clean absorbers count.
To enter in SERVICE MODE
1) Power off Printer
2) Push and hold "Resume" button and then push and hold "Power" button
3) Hold the Power button, then release and 2 times press Resume button
4) Led indicators must change
5) Release all buttons
6) Then printer in Service Mode
(If something wrong, repeat 1-6)
To clean absorber counter,
7) Press "Resume" Button 4 Times and after press Power button. It's all! Your absorber count is EMPTY!
In SERVISE MODE you can do several useful things:
To print Service Nozzles test, press "Resume" 1 time and press Power
To print EEPROM data, press Resume 2 times and press Power.
DO NOT press Resume 3 times and POWER. It will reset some EEPROM data settings
Any Question mail me: ossipenko(prettydoggy)gmail.com
SOURCE: The waste ink absorber is full.
You have to contact the Canon agent to get the waste absorber replaced. or you can continue it with pressing resume everytime.
SOURCE: Ink absorber is full.
Try this:
How to clear E27 Waste ink absorber full
1.With the printer powered off but connected to a power source,
press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is lit, press the Stop/Reset button two times
while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button (regardless of order),
the printer will move into a service mode. (Waiting for menu selection)
4. When the on/off lights in green, press the Stop/Reset button the
specified number of time(s) according to the function listed in the table below.
(Each time the Stop/Reset button is pressed, the LED lights alternately in orange
and green, starting with orange.)
Note: press 4 times for waste ink counter reset.
The number of the Reset button pressing LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5.Turn off the printer.( it must be turn off) then turn it on again
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
