Question about YouTube Videos
Fitting door catch Servis Rainwave 900 washing machine
Servis washing machine door latch
    Top Expert:
  • 4,961 Answers
You might want to post this question in the washing machine section so the proper experts will see it..
Posted on Aug 19, 2012
6ya staff
SOURCE:
Tip
How a washing machine door interlock work & How to test.
At the same time, power is passed through the interlock on to the rest of the machine. The actual latching shut of the door is a simple spring-loaded mechanism where the latch just slips into the door catch and the door stays closed. Locking the door is a separate process..
this link will help you to find out if it is your interlock thats faulty or not.
How washing machine door interlock work How to test
on Dec 14, 2017 | Washing Machines
MACHINE KEEPS DISPLAYING D.E AND WONT WASH
D E error is Door Error. cause : Door latch, Wiring or Control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Mar 07, 2016 | LG WM3070HWA 3.7 cu.ft. Extra Large...
Servis easi logic 1500
the doors can be dismantled and a new handle fitted. if you go to google. type in the make, model and end it with spares, it should come up with companies that supply parts. in the uk i use espares.
changing it can be fiddly but take pictures as you strip the door down so you get the pin, catch, handle and retaining spring in the right positions
May 01, 2014 | Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
How to change door lock on servis 1000 gem washing machine
I would guess that the plastic latch hook (my invented name for it) has broken. Easy to do because the wretched design does not show whether the lock is still on or not. When you have your replacement you just have to remove the two screws inside the door latch, noting how it all fits together, and refit the new kit. Careful with the screws; one of mine is now loose and will need plugging. BTW I have managed just one wash with a super-glued latch hook!
Mike.
May 21, 2012 | Washing Machines
My servis m6755b washing machine door wont open
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 07, 2009 | Washing Machines
Door does not open after a wash cycle
Hi
the door lock is you problem. just replace and should be back to normal.
regards
Mar 01, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Door not closing
If you dont have a problem with the catch, then either your door latch is defective or possibly a wire has burnt off or come loose from the connecting point
Jan 27, 2009 | Asko W6761 Front Load Washer
YouTube Videos Logo
135 people viewed this question
Top YouTube Computers & Internet Experts
LP
Robert Salgado
Robert Salgado
Carlo Barzo
Carlo Barzo
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
