I am Having Intel DG31PR Motherboard. OS-Windows 7 Whenever I connect two USB Devices to any of the USB PORT, the OS stops responding after 2-3 minutes. I have formatted couple of times. I have updated BIOS also, but still no use Plaese Help.
SOURCE: Intel DG31PR Motherboard
Did you get an error message during install of the (system with the SATA 160GB drive)? Make sure the 160GB drive is shown in the bios. Than go to the title, Boot in the bios & make sure the SATA 160GB is listed in the boot order. (Preferred 3rd. boot device)
Please go to the SATA drive's manufactures site & download either their bootable floppy or CD setup software. (It’s free)! Use their software to setup the FAT & cluster size on the drive. You can even set other features that neither the bios or windows can do. Format the 160GB drive with the software as well. The manufacture's software does a better job than windows. If the 160GB drive is a SATA 2.0 leave the jumper on the drive alone. The Desktop Board supports four Serial ATA channels (3.0 GB/s) via ICH7, connecting one device per channel.
Again, please run the manufactures setup software for your SATA 160GB drive. (Disconnect any other drives that may be in the system until windows is installed).
Intel's web site here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Good luck ameyaniks!
If I missed something, just let me know.
Mike
SOURCE: Problem with video drivers And LAN card adapter
Well.... if you want to buy the diver CD. Just ask them " Intel D845GVSR Driver cd" if you want to download from internet then goto
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065&lang=eng
SOURCE: USB problem
Dear Sohamroy,
please install windows service pack 2. then try to update your windows with the help of this link www.update.microsoft.com.
SOURCE: Problem with installing win2003 on motherboard DG31pr.
have you checked the bios to see what IRQS are assigned to what device. Normally this auto conifigs but make sure any way as it sounds like there is conflict in the IRQS. Also only connect the basic devices while installing so that you minimise the amount of IRQS used. Also If you have another operating system see if it has the same prob installing. One other quick thing to try is reset the bios to factory settings. To enter bios do a cold boot and press the displayed key to enter set up i.e. f12,del or f2
SOURCE: mac os x is not run imy pc
to install mac os is simple in dg31pr motherboard but if it does not support to u mean. u have to change in bios some setting it is change hardisk mode from ide to AHCI
Then I think some of the capacitors on your motherboard are starting to die.
Ok. Thanks for the help.
