SOURCE: access to parts in washing machine
2 men 2 hrs minimum tub halves are bolted together and entire assembly will need to be removed bearing is not a service part entire rear shell will need replacing and probably basket also due to shaft scoring better ck for warranty
SOURCE: the drum on my front loading wash machine is very loose
I recently replaced my bearings and seal for about $60. I could have bought the bearing cheaper online but I was in a hurry. If you do a search online there are several blogs about replacing these bearings. Here is a link for a service manual for $ 18 http://www.repairclinic.com/SSPartDetail.aspx?PartID=659075&PPStack=1 You pretty much have to disassemble the washer but it is not really that difficult depending on your mechanical experience. The manual should lay it all out for you. There are 2 notes on these frigidare washers: Sometimes the spider arms on the inner drum break and you will have to buy the complete inner drum assembly. I have heard they are warranted for 25 years, but they most likely will not warranty them if the owner does the work. Also, Frigidare does not list the bearings seperately, but you can buy the bearings from a bearing supply house, online or in your town. The bearing numbers are on the side of the old bearings when you remove them.
NOTE- The bearings that came out of mine were 6306-2Z and 6307-2Z (shielded) I replaced mine with 6306-2RS and 6307-2RS (sealed). The significance is that the shielded bearings offer minimal protection from water where the sealed bearings are built to seal out water/contaminants if you new seal ever fails. The seal I used was a CR15939 rubber coated seal.
If you need any other information, let me know
Hope this helps
SOURCE: bearing on front load washing machine needs replacing (Frigidaire
You will need to replace the tub rear shell/bearing assembly (part # 131525500).
To do this, practically the whole machine will need to come apart.
To remove the drive pulley, remove rear cabinet panel. Remove the pulley screw and pull back on the pulley (you may need to giggle it as you pull to remove it).
For the shock pins, grab the open end with a pair of vise-grips. On the "pointy" side of the pin press the tab in with your finger (if you can't push the tab in slide a 9/16" socket onto it) and pull the pin out with the vise-grips (twist back and forth slightly as you pull).
A qualified tech could replace the rear shell/bearing in about 1.5 - 2 hrs. I can certainly give you more help if you need it, let me know.
SOURCE: Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
SOURCE: How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
