Question about Frigidaire Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
  • 1 more comment
  • david arledge
    david arledge Jul 24, 2017
    I can "absolutely, positively" confirm that the track that +Joshua Day and +sass_jonatha are on the 'Right Track'~!
    I have a FFMV162LBA and if you know the right key combination you can enter 'Programming Mode' on anything electronic from a Timex Watch, to your Microwave to your cell phone. This concept has been around since the 70's but, not available until much, much later in the U.S. on residential equipment. If it has "Software" or at least a "Logic Circuit" to control the functions (in other words it can't be a mechanical switch) then it has a 'Programming Mode'. The engineers put them in the software or logic sequencer to enable Technicians to preform "Warranty Repairs".
    On the one prev mentioned (162LBA) by pressing the 'STOP/Cancel' button and holding it for 6secs then "All Keypad Functions are Disabled"~! To restore: again hold 'STOP/Cancel' for 6secs (this time the keypad will not beep, of course, when you touch the button).
    A call to Electrolux at 800 944 9044 in the USA should allow for some sort of phone tech support above the Customer Service level (this means you have to interface with Customer Service to get to that level).
    GOOD LUCK~!
  • acmservice Aug 28, 2017
    Cathy, is the microwave jsut Beeping on its own like you are pushing a pad? but you are no where near it?? You hear it from the other room?? If so the problem , mnost likely, is the touch pad. It has a colappsed air pocket for one of the pads, and the main board sees that like you are pushing the pad. The only fix is to replace the touch panel. Some are pricey, others not so bad. First unplug the unit, then The front panel where you puch the pads has to come off and the Controll board removed and the old panel taken off to put the new one on it. If youve never done this , you may want to check with a repair company for an estimate first. Probably can be repaired without taking down. Not a horrible repair.
  • Shari Deines
    Shari Deines Jan 25, 2018
    Found this in my owners manual, works
    http://manuals.frigidaire.com/prodinfo_p...
    Info on page 26
I was wondering if you found an answer... I'm having the same problem!
Posted on Jun 20, 2019
    New Friend:
The only way to stop the beeping is to push the cancel button then immediately open the door. This is the only microwave Ive ever encountered that doesn't stop the beeping when you either open the door or push the cancel button. To make it even more irritating, the beeps are VERY loud and long. Here is a short you tube video posted by someone who recorded this loud and long beeping I am referring to. https://youtu.be/pDq7LTpPNTY
Posted on Dec 02, 2017
  • Frigidaire Master
  • 9,179 Answers
Some models have a feature which will allow you to turn off the beep.
check your owner's manual. If you don't have your own owners manual, look for a button that says custom help or info or something like that. And then press that and look at the choices you are presented with.
Otherwise, you should be able to find a manual at http://www.frigidaire.com
I also have a YouTube video which shows you how to remove the beeper if you want to take such a permanent approach. https://youtu.be/ITHDE-vFaiw
Posted on Jun 30, 2019
  • William Miller
    William Miller Jun 30, 2019
    Also, this sequence works on some Frigidaire models.
    New Friend:
All of these answers are wrong. You will have to remove the clock panel and remove the buzzer. You tube videos demonsteate.
Posted on Jul 08, 2017
    New Friend:
First press "user pref" button, then the 2 button (for the sound menu) and then press the stop/clear button (for off).
Posted on Aug 31, 2015
  •  Kathleen Noonan
    Kathleen Noonan Oct 08, 2015
    My microwave doesn't have a "user pref" button. I've tried everything. Nothing is working. There is no menu on this microwave that I can find.
  • Charles
    Charles Dec 24, 2017
    This worked. Hit Clock Settings twice, then Op-2 display, Hit Start+30 lo/nor/Hi/oFF scrolls. Touch Start at the oFF display.
    New Friend:
All you need to do is hit stop once it starts to beep!
Posted on Apr 18, 2015
  • 1 more comment
  • Jeffro Doe
    Jeffro Doe Dec 02, 2017
    Wrong. On these Frigidaire units neither opening the door or pushing cancel stops the beeps. It works on every other microwave on the planet, but not this one. To stop it you must push the cancel button then immediately open the door.
  • Jennifer MacGeorge
    Jennifer MacGeorge Apr 04, 2018
    correct actually. You have to hit stop BEFORE opening the door, and it will, in fact stop beeping. If you open the door first, it will NOT STOP for three long loud beeps.
  • Dave Cullen
    Dave Cullen Jul 08, 2019
    What an obnoxious answer from Tom. This means every time I heat something, stand by the unit while it works?
    Sometimes I'm across the room. I have to hear all 3 long, loud beeps. And then if I don't rush over and do it then, if I get distracted, it does it again in a few minutes. It seems to repeat forever.
    New Friend:
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Posted on Apr 05, 2013
  • Anonymous Jul 31, 2016
    HI, thanks but when I hit the 2 it automatically starts cooking, then I hit at same time it beeps and an icon appears but then it won't accept any commands just doesn't respond at all until I repeat holding 2 and start at the same time? HELP IM LOSING MY MIND! Model#FFMV162LW
  • Dave Cullen
    Same for me.
6ya staff
SOURCE:
How do i disable the beeper
Hello Friend, thank you for allowing me to assist you!
I see that your question is listed under Frigidaire microwave FFCE2238LW. Typically you will hear a series of beep once your food is done heating or defrosting has finished. For this purpose, the beeping signal cannot be deactivated and I show that the volume is not adjustable for your model. Most microwaves are preset to do this. Best regards! - Z
Aug 26, 2014 | Frigidaire FFCE2238LW Microwave Ovens
Can you turn down the beep on a Frigidaire microwave
Good Morning Friend,
I understand that you want to turn down the beep on your Frigidaire microwave, model# PLMV169DC. You are not able to turn down the beep, but you are able to turn it completely off. If you wish to have your microwave oven operate with no audible signals, touch Help, the number 2 and Clear/Off. To cancel and restore the audible signal, touch Help, the number 2 and START. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire PLMV169DC Microwave Oven
Why has my frigidaire microwave (model PLEB30M9ECE) stopped beeping. It still cooks but no longer beeps
Good Afternoon Friend,
I understand that your Frigidaire microwave, model# PLEB30M9ECE, is cooking, but has stopped beeping. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and try any cooking cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Microwave Ovens
GE JES1344SK01 microwave: turn off reminder beeps
I checked my GE micro information and nothing is said about disabling that annoying beep. Guess GE feels it is for your own good, like a noisome nanny.
Jan 02, 2014 | GE JES1344SK Microwave Oven
My child lock on my Frigidaire is constantly beeping... The door is not locked but it is beeping...
Hello Shelley, thank you for your inquiry!
I understand your Frigidaire is constantly beeping while they door is unlock, however do you have a range or microwave Frigidaire appliance? The serial tag for a range, which lists your model number, is typically located in the storage drawer, on the right side and the serial tag for a microwave is in the lower left corner as you open the door. With this information I can better address the issue at hand. Thank you!
Oct 22, 2013 | Frigidaire Over-the-Range Microwave
Frigidaire microwave oven model # ffmv162lba seems frozen, pushing buttons does nothing
I have the exact same microwave and had the same issue with it having locked itself. I held the Stop button for 5 seconds and it unlocked itself with a beep. That was easy!
Sep 13, 2012 | Frigidaire Microwave Ovens
Emerson Microwave oven and grill MWG9111SL
teashas_tasty_treats@yahooo.com
i have the same problem too! please help if you can.
Oct 25, 2008 | Microwave Ovens
Microwave Ovens Logo
23,954 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
