I have 2 sony tvs panel tv and one big screen floor model both are blinking panel tv will not turn on and floor model turn on then right back off?
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can
be selected from the drop down box menu at the left top corner or the display
window. It will make search easy. Some times, the ads attached with each posts
might help you to find the availability of spare parts. There are more than 640 posts to different brand TVs.
SOURCE: Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
SOURCE: Sony KV-32HS420 will not come on has blinking standby light
Get out your original remote and hold the "Setup" button at the same time as holding the On/Off button on the TV set. It just worked for me!! Thank goodness. I was just about to bring it for repair but there's a snowstorm. Here's the link I got this from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
SOURCE: sony tv kv-36fs120 will not turn on
Use a hair dryer on the back right side of unit. Humidity sensor may be causing the unit to stay off. The hair dryer may also remove dust causing a false humidity detection
SOURCE: SONY TV MODEL kv-27s40 BLINKING RED LIGHT 2 BLINKS
The 2 blinks usually mea an over current problem. Perhaps the most common cause of this is a shortde Horizontal Output Transistor (HOT). If you can solder, you should be able to repair this yourself. Realize that there are potentially dangerous high voltages present inside the set even when unplugged. Look for a 3-legged ransistor attached to a heatsink close to the flyback (part with large red wire coming out the top). The part will be marked C5438 or something similar. Post that marking here nad I'll confirm the entire part number.
Keep us posted.
Dan
