How can I tell if the HD is working if the computer won't boot?
I don't think you can. If you take it to have a geek look at it, the first thing they will do is pull the RAM out, look at it to see if there is anything obviously wrong with it -- then re-seat it and try the machine again. So, you may as well at least do that. The RAM is behind one of the panels on the bottom of the computer. If there is two, pull both and try it with only one of them. This will start you on a process of elimination in case one is bad / one is good. But don't be disheartened yet if there is only one. It can loose adequate contact, and just pulling it and re-seating can fix.
Toshiba builds a good machine. But, they are bad about getting clogged up with dust. If you don't take them apart ever so often and clean the dust out, it can become completely clogged at the out-vent. This of course causes a barely adequate ventilation system to become not adequate. And your machine begins to overheat. And that can damage the motherboard or the processor. So, once a year or so, I take mine apart and clean it out. The last time I did this the out-vent was completely matted over in such a way that the dust appeared to be a filter of some sort. I was confused for a minute (even though I've done it before) and then, "Oh sh$#, there are NO FILTERS!!!" The first time I did this, there was actually a ball of dust that had been rolling around in the fan housing, like a snow ball, getting bigger and bigger. It finally jammed the fan, and that's when I knew there was a problem - because I had become used to hearing the fan (a lot). And that's another thing to mention; If you start noticing that it seems like the fan is real loud, like running real hard all the time...that's because it is. And that's because your computer runs a little program that tells the fan how hot the processor is.
I hope all this helps you. If yes, please take a sec to rate me. Thanks!
Don
