Uniden Cordless Phone Logo
Anonymous Posted on Aug 18, 2012
Not working I have replaced the battery, but the phone still wont charge.
Computer Repairing
Level 3:
  • Uniden Master 14,641 Answers
  • Posted on Aug 19, 2012
Computer Repairing
Uniden Master
Level 3:
Answers
14641
Questions
0
Helped
719509
Points
53082
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
My Samsung phone wont turn on
make sure battery is charging, if not replace the battery. Sometimes the charger wont charge the phone depending on the type or sometimes the stop working.
Dec 07, 2014 • Cell Phones
Why wont my one touch premier battery charge?
Try a different charger if still no charging then replace phone battery
Wont' stay on and wont' charge
If your telephone wont stay on and wont charge, then you need to carry out some test to know where the fault is from. First, test your battery if it is working by inserting it in another phone then charging it for about 3 hours then power on the phone to see if it will come on, if it does, then it means the battery is alright. But if it does not come on, then you know the battery is bad and needs to be replaced.
Now test the phone by inserting a well tested battery inside the phone then power it on, if it comes on, then the phone is alright, but if it does not come up, try to prop the battery so it will connect tightly with the terminal of the phone, then power it on, if it comes on, then it means the battery was loose and just need some propping, but if it still does not come on, then there is a problem with the phones power panel.
Test the charger also, by trying to charge another phone with it to see if it will work, if it charges, then it means the charger is alright and if it does not charge, then it means the charger is bad and need to be replaced.
After carying out these tests, you will be able to tell which component is faulty and needs replacement.
Take care and good luck
Dec 29, 2010 • Cell Phones
Why wont it charge?
just check your charger first. if its working condition is perfect then replace your battery with a temporary battery and check its working.
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
Lg Veiwty- battery died, so i charged it, still wont turn on
yes the battery is dead. replace it. cant help ypu anymore as you alone can replace it.
Aug 31, 2009 • Cell Phones
2answers
Sony ericsson W901i wont charging
listen whereu part the charger pin that is damge need to replace that part then it will be work
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
1helpful
Wont charge
Usually when a rechargable  battery won't take a charge it need to be replaced.  I have had good luck purchasing replacement phone batteries on ebay but you can also try a local phone store or Radio Shack.  Its possible your charger is bad but it is usually a bad battery as they have a finite life where the chargers seem to work forever unless damaged by being dropped
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
