There is a small chance the Excel was set to automatically make timed backups of the files after a certain time, such as ten minutes. In that case, there are programs that could possibly "undelete" the earlier version of the file from either the thumb drive, or either of the original computers (yours and theirs) used to edit it.
Hi,The fastest way to do this is to download the DataWedge software free form the Motorola website. You can then scan code directly into any file that excepts text based input. To get the text file on to the unit i would recommend an SD card. or setup Active Sync to sync a Pocket Excel File to your desktop. If you need some software writing with some specific requirements. Please call Pen Mobile (google us)
P4-3.40 GHz (800 FSB, L2 cache:1MB, rev.G1) is the fastest CPU listed. The 1MB cache makes this CPU the fastest of the bunch. You may need to flash the bios in order to run this CPU. Click the Go button to the right of the CPU listed to update you're bios if bios version No# 1006.002 is not installed.
In the past the fastest way to fix this is to go directly to the file and try to open it. It is possible that file or database has been corrupted. In some instances the file type dwg is not associated with autocad and the application hangs because it is looking for .dwg as an associated file type to autocad.
Let me know if you need further clarification.
assuming you have Excel sw on your PC. Assuming you are running XP. Assuming you can start your Excel and Open any excel file using File/Open within excel.
You must associate Excel file with Excel program in your Windows Explorer. Fastest way is Browse to any excel file with your Windows explorer (NOT IE) Right click and select Open with... Browse to find your Excel MSOffice program Select Use always to use this program OK
What is your phone ? If it has blue tooth you can pair to a bluetooth enabled Laptop and transfer files.. Else , try to get a data cable and software depending on you phone and you can then transfer. Data cable specific to phone is fastest
