Question about Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
I have to press up on the door to make it heat
I close the door, press desired time and start. Light comes on inside, fan runs but it doesnt heat and dish doesn't turn unless we press up on the bottom of the door and hold it
  • 746 Answers
Rich,
It sounds like there is an issue with the interlock latch or switch that allows the inverter to operate. Check the following:
The door hinges to be sure they aren't loose, misaligned or bent.
Check the latch on the door to be sure it engages the cam inside the main unit solidly and that there isn't any play in the door. Also check the door gasket to make sure it isn't preventing the door from closing properly. Since you said the unit was over the stove, things can become misaligned from the stovetop heat.
You may be able to able to fix this, but it may require partial disassmebly of the microwave. If you are unfamiliar with this type of service, it's best left to a trained service tech.
You should disconnect the power before attempting any repairs.
Posted on Aug 18, 2012
4 Suggested Answers
6ya staff
SOURCE:
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Ihave a whirlpool microwave RM278BXP----the
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Posted on Feb 22, 2011
localwonder
Michael Masters
  • 6784 Answers
SOURCE: microwave not working
HI, this is a faulty control panel. replace asap if possible.
Posted on May 29, 2009
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: microwave oven will not start after I put in the time. It says open and close door and press start. Still won't start
Probably a bad door switch or mount. The door switch help file is here.
On some models though (you didn't mention yours) the door circuit is very complicated, and may be showing the door error due to a blown fuse or cavity TCO.
Accessing the cavity TCO for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Whirlpool owner's manuals and installation instructions here.
The drawing below shows what to check:
You can find handy exploded views and order parts by model number
here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 20, 2011
Ge pvm1870DMWW
Verify the door micro switches.
Aug 30, 2017 | GE Microwave Ovens
Light stays on and won't start
emerson mecrowave mw81195bm clock works but I can heat anything it doesn.t work inside
Oct 22, 2012 | AEG MCD3534EM Stainless Steel 900 Watts...
My microwave displays time etc, but does not turn on
That model number from the tag on your oven should be KCMS1555SS0, KCMS1555SS1, or KCMS1555SS2.
We would need more detailed information about what it's doing or not doing.
Does it respond to key presses?
Does the inside light come on when you open the door?
Can you enter the cooking time?
What happens when you press "Start"?
Does it run but not heat?
Does it count down but the inside light and fan do not come on?
Please post a new help request with the model number and detailed sympotms.
May 25, 2011 | KitchenAid KCMS1555SSS Microwave Oven
Starts when closing door
This is a list of possible causes. 1. Defective triac or relay 2. controller is confused (pull power cord for a minute and see if it resets) 3.Defective controller or touchpad.
Mar 02, 2010 | Microwave Ovens
Microwave seems to run, but won't heat.
We have a similar problem! It sounds like a problem with the microswitch inside the unit that the door is suppose to engage when closed. If not engaged properly, it will not cook. We had the switch replaced last March but it has started acting up again. We can press in on the door and/or lift it slightly and it will cook. Try putting time on the counter and hit start. It the word "cook" appears then try moving the door slightly and see if the turntable starts turning. If not, then you may have a more serious problem. Good luck!
Oct 09, 2009 | Frigidaire FMV156DC Microwave Oven
Microwave continues to run when the door is closed
Did you pressed the stop/clear button? or disconnect the micro.. for a couple of hours and try again?
Apr 04, 2009 | Microwave Ovens
GE spacesaver jvm240av microwave shuts down during cycle
I have not gotten a solution for this problem. I thought your website said one of the experts would respond for free. Seems like that must have been a hoax to give you the opportunity to sell me something. Shame on you!
I am still waiting for the free assistance, as advertised.
Dave
Nov 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Nnt553w panasonic microwave. Whilst heating something he oven stopped and the display said refer to operating instructions. Now seems to be working but doesn't heat.
When you enter the time and press Start:
Does the inside light come on?
Does the turntable rotate?
Do you hear the internal cooling fan running?
Does the time count down?
May 25, 2008 | Panasonic Microwave Ovens
Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave Logo
198 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
